SDRTrunk Playlist unable to login to Radioreference
wa3riz
King of Prussia, PA
Hello
Currently trying to setup sdrtunk v0.5.0-alpha6 on windows ten.
ERROR i.g.d.g.p.r.LoginDialog - Login failed. Invalid username or password. Can't login to radioreference.com
This error occurs 'after' I acknowledge the failed login message from "Test Connection"
After hitting 'OK' login without the test, the popup closes but nothing else happens, including no error message in the log.
I suspect that the creds are supposed to be getting written into a file and that file is for some reason not being created.
I say that because the install instructions say that the creds are stored cleared text in a file but I cannot find that entry in any readable file.
Thank you, Jeff
TomLine
Hamilton, Ohio
Did you ever resolve this issue? I'm getting the same thing. I can hear calls, just would have to manually enter a TON of talkgroup entries without the function.
TomLine
Hamilton, Ohio
Did a Wireshark capture. Sdrtrunk connects to 13.32.182.36 but gets a reply 500 - internal server error from radioreference. There's a dns trace before that references a site that's in the radioreference.com domain to get the 13.32.182.36 address.
