SDS 100 display
KAUC1632
Is it possible to set up the simple view to be able to see the trunked frequency or is this only possible to see on the detailed display mode?
JD
n1chu
Farmington, Connecticut
Either setting should show the frequency. Unless you have the display colors customized and have the frequency color and the background color the same...
mc48
Monroe County, NY
Yes it is, In Sentinel Tools>select model>SDS100. then go to Edit Display>Simple Trunk>Select a location for Freq>Right side color panel top >Option Item>Drop down menu>Frequency. You can also edit the display with the radios display options.
KAUC1632
Hmmm...............not finding frequency in the drop down menu. Can you advise?
