I have a totally weird issue going on now. I just updated the master database in BCDx36HP Sentinel software on my pc. After that i did a write to scanner and force write full database.
Now when i use my scanner it shows nothing to scan for certain zip codes. for other zip codes it cycles only through a few systems and departments and repeats them over and over.
I havent changed anything else on the scanner itself. FUll DB is set to on, all servcie types are on and so for. Just as I always use it.
However, when it shows me nothing to scan. I can press the channel button and then I see all systems and departments and can cycle through them freely. However, as soon as i press channel again, it shows nothing to scan...
I think something is corrupt with the files the pc writes to the SD card. Maybe a windows update broke it again. Had that issue in the past...the whole database was broken even though it wrote just fine to the scanner...
