I have one of the SDS-200 scanners and am currently trying out Proscan for remote control and listening.
This is what I am trying to accomplish: Have the scanner installed at one of my tower sites to monitor a frequency (or frequencies) to determine what entity we are receiving. The site has a Cradlepoint Cellular Router and a Microtik RB-250 switch with open, unblocked Internet. I have opened ports 554 TCP and 50536 UDP and forwarded the ports to my scanner's private IP and confirmed that I am not double NAT'd.
I have given my scanner a static private IP and connected it to a LAN port. When I connect to the router via WiFi with my PC, I can enter the IP address and control the scanner AND listen to audio with no problems.
The problem occurs when I try to connect to the scanner from another Internet connection such as another Cradlepoint router or the hotspot on my iPhone. I am able to connect to the scanner and control it and see the display but I cannot get any audio to pass. It never assigns a Scanner UDP port (it shows "0") when viewing the Audio Control > Source Client tab.
I have tried power cycling the scanner as well as disabling the IP and re-enabling it as outlined in the instructions to no avail.
I'm not wanting to set up a web server or Remote Scanner over IP, just want to be able to remotely control with the Proscan software. At this point I'm not sure if that is even possible.
I reached out to ProScan and he recommended I check here to see if anyone else had done the same thing or seen these problems.
Maybe there's a better piece of software for what I'm wanting to accomplish. Any thoughts along those lines?
