SDS100 Keypad Shortcuts Thread
LZJSR
California
I noticed in several posts that there are some handy keyboard shortcuts available. I figured I would see if I could start a thread to group them all into one thread (cut and paste previous, then add yours).
On the SDS100, I saw that :
F + Long Key Press (9) = Black/White mode
Please add more to this thread to help us newbies get the best information for the scanner in an easy to use reference.
Thanks!
CQ
Exosphere
It's Still There...
Thanks!
Copy and paste. I couldn't cut (remove) from your post so I copied (replicated) it.
The most widely misused action.:p
racing1
How do I set a certain site to a quick key?
Sent from my SM-G965U using Tapatalk
LZJSR
California
Sorry if I was not clear what I was hoping for
I apologize if I was not clear on the keyboard shortcut post I posted...
I was hoping that we can start a running list of many keyboard shortcuts (i.e. the black and white display switch) for SDS 100 owners/future owners, in order to group them into one thread.
Please post any you know about to add to the list.
kikito
North Pole, Alaska
Here’s one someone brought up in another thread:
Quick press of the Power button will toggle the display backlight on or off.
Hit_Factor
Saint Joseph, MI
Here are the keyboard shortcuts from the manual:
Power/Light
• Press and hold to turn the scanner on or off.
• Tap to turn on/off the display backlight. Note that when the display backlight is off, nothing is visible on the display.
Avoid
• Press once to temporarily avoid the current channel or frequency (in direct tune mode).
• Press twice to permanently avoid the current channel or frequency.
• During scan, or scan hold press the left soft key (System), then tap avoid once (for temporary avoid) or twice (for permanent avoid) to avoid the currently scanned system.
• During scan, or scan hold press the middle soft key (Department), then tap avoid once (for temporary
void) or twice (for permanent avoid) to avoid the currently scanned department.
Zip/Services
• Press to enter country-zip/postal code.
• Press Func then Zip to select Service Types to be scanned.
Soft Keys
The function of these three keys change depending on the current
mode. The function is indicated by the labels at the bottom of the
display.
Menu
• Press to enter Menu mode.
• Press to return one level in Menu mode.
• Press Func then Menu for Search menu in Search mode.
• Press Func then Menu for Close Call menu in Close Call mode.
Replay/Record
• Press to Replay the last transmissions.
• Press Func then Replay to start/stop recording
• Press and hold to Review Recordings.
Number keys (general)
See individual key functions below for additional functions
• Press to select Favorites Lists in Scan mode.
• Press 0-9 to use direct entry in a Hold mode.
• Press 0-9 to toggle custom search bands on or off in Custom Search mode.
• Press 0-6 to toggle Close Call bands on or off in Close Call mode.
1 / SRCH1
• Press to enter the digit 1 in any numeric entry mode.
• In channel hold mode, press Func then 1 to toggle on / off the search you’ve assigned to SRCH1.
2 / SRCH2
• Press to enter the digit 2 in any numeric entry mode.
• In channel hold mode, press Func then 2 to toggle on/off the search you’ve assigned to SRCH2.
3 / SRCH3
• Press to enter the digit 3 in any numeric entry mode.
• In channel hold mode, press Func then 3 to toggle on/off the search you’ve assigned to SRCH3.
4 / ATT
• Press to enter the digit 4 in any numeric entry mode.
• In Channel hold mode, press Func then 4 to toggle attenuation on / off for the current channel
• In Channel hold mode, press Func then hold 4 for 3 seconds to toggle global attenuation on/off.
• In Search mode, holding on a frequency, press Func then 4 to toggle attenuation on/off for the current frequency.
5 / DIM
• Press to enter the digit 5 in any numeric entry mode.
• In Channel hold mode, press Func then 5 to set the display brightness level.
6 / WX
• Press to enter the digit 6 in any numeric entry mode.
• In Channel hold mode, press Func then 6 to toggle weather priority on/off.
• In Channel hold mode, press Func then hold 6 for 3 seconds to go to weather channel monitoring mode.
7 / IFX
• Press to enter the digit 7 in any numeric entry mode.
• In Channel hold mode on a conventional channel, press Func then
7 to toggle intermediate frequency exchange on/off for the current channel.
• In Search mode, holding on a frequency, press Func then 7 to toggle intermediate frequency exchange on/off for the current
frequency.
8 / REV
• Press to enter the digit 8 in any numeric entry mode.
• In Channel hold mode on a conventional channel, press Func then 8 to monitor the the repeater input frequency for the current channel.
• In Search mode, holding on a frequency, press Func then 8 to monitor the the repeater input frequency for the current frequency.
9 / DISP
• Press to enter the digit 9 in any numeric entry mode.
• In Channel hold mode, press Func the 9 to toggle between simple
and detailed display modes.
0 / LVL
• Press to enter the digit 0 in any numeric entry mode.
• In Channel hold mode, press Func then repeatedly press 0 to set
the volume offset for the current channel.
. / NO / PRI
• Press to enter a decimal point for a frequency.
• Press when prompted Yes/No to select No.
• Press Func then./no to toggle conventional priority scan.
E / YES / Q. SRCH
• Press to select a menu item or save an entry in Menu mode
• In Channel hold mode, press to store a blinking CTCSS/DCS/NAC.
• In Channel hold mode, press Func then E/yes to start a Quick Search.
• Press Func then E/yes to toggle ID Search mode on/off in Scan mode (when scanning Trunked System in Favorites List only).
