Season 3 Skinwalker Ranch
RichardKramer
Reading, PA
The first episode of season 3 of Skinwalker Ranch on the History channel is scheduled for May 3, 2022 @ 10Pm Eastern. The rest of the season 3 shows will start at 9Pm Eastern. Has anyone found the freq of the radios that they use around the ranch?
Ravenfalls
Check FCC records or try common channels.
RichardKramer
Reading, PA
I watched the first episode on Tues and copied these helo freqs down that were on the display while they were doing some tests:
129.950 - 135.175 - 124.75 - 130.85.
129.950 used at McCarran Intl by Virgin America
135.175 AWOS at Reno/Stead
124.750 ATIS at Salt Lake Cty Intl
130.850 Misc airlines/I'm assuming the helo used this freq to talk to the guy on the ground who had a VHF transceiver.
kv5e
T¹ ÆS Ø
The radios used during production are likely rentals, a near field search of itinerants from UFO Valley Ranch would probably find what is used.
Everything I have heard is analog on the show.
Adamantium Real Estate LLC and a search of the Colliers address in SLC do not yield any results.
Nearby Moonshadow Ranches uses 464.0875 simplex with 5 20 watt MO with 11k3F3E emission type.
RichardKramer
Reading, PA
S3/Episode 2 had 3 guys from Apex set up their suv with surv equip to monitor rf detection when the skinwalker crew lauched some rockets over the triangle. The Apex surv equp shut down twice just before a rocket launch for no apparent reason. One of the Apex guys got sick while in the comm center as the sdr in the background showed a huge spike in the 1.6GHz range.
S3/episode 3 had a Cessna fly sweeping patterns over the triangle. The scientist onboard had 5 gps trackers that were recording as they flew at different altitudes. They were using 123.450 for a/g comms. The Cessna got rfi (buzzing/grinding noise) on their radios and in the comm center the rfi freq popped up in the 1.6GHz range on the sdr. There was also an echo of their comms while the 1.6GHz freq was on which the crew thought might be some type of eavesdropping device. Only 2 of the gps trackers recorded any info, the other 3 units didn't work at all even though they were thoroughly checked before the Cessna took off. One of the gps trackers showed not only above ground readings; but also showed the a/c flew 62.5 miles underground. The scientist onboard the a/c said he saw a shadow of another a/c fly below them at the triangle; but the guys in the comm room and the observer outside saw no indication of any a/c in the area. They did have adsb up and saw other commercial a/c in the area, but none over the triangle at the ranch.
On an earlier episode when the helo flew over the triangle the helos radar indicated an object about 50' under the helo. When the video from the helo was played back there was a black streak of an object that flew under the helo.
RichardKramer
Reading, PA
S3/Episode 4 had some experts with $1K+ telescopes that everytime they trained the scopes over the triangle, the scopes computer programs would shut down. As soon as they turned the scopes outside of the triangle, they would work. The computer program to set up the scopes with the stars would delete the stars in the computer program for no reason when the op attempted to set up the scope over the triangle.
They shined a mil-spec laser above the triangle and at about 2K' the laser was bending around something that was blocking it although nothing could be seen of the object visually, the laser actually was turned into a Y (the ends of the beam split in two) near this object. During the event a ufo that was circular with a dark center appeared moving west then east over the area.
Early in the morning the scientist that lives in the trailer on the property was awakened by something banging on the trailer, but nothing was found outside. He went into the comm center and reviewed the camera footage of the sky, (they put 360 deg cameras up to view the sky above the ranch), and saw a uap appear at the same time with a burst of bright light. The rfi appeared at the same time on the sdr 1.6GHz.
There was no rfi on the radios, but the cattle were herding as close to the fence as they could get as something was spooking them.
The guys with the scopes were well experienced astronomers and they said nothing ever happened to their scopes like it did on the ranch.
kv5e
T¹ ÆS Ø
Erik Bard gave a nice demo on the Insider Livestream. This sure beats Tri-field and other low end USB based spectrum processors and adds DF capabilities. Mr Fugal is putting his money where his mouth has gone as this is a serious research tool and Erik has the skills to optimize it for their purposes.
