jack3726
Unless I am missing it, is there an easy way to identify encrypted TG's in the master database once you download it or is that not supported.
Yes it does...@ProScan Rocks ! ! !
Good question... Everything I did was full encryption... Not partial...All, thank you for the information. The last part to my question which you provided the answer to as well was what you can do with ProScan and you mention it can skip the import of encrypted TGID's. Does it skip the lower case encryption as well or just the full encryption's.
I just tried it with a partially encrypted (mode Te) talkgroup, "don't import..." checkbox checked and it imported the TGDoes it skip the lower case encryption as well or just the full encryption's.
So it only will not import the full "E", but will a partial... Correct?I just tried it with a partially encrypted (mode Te) talkgroup, "don't import..." checkbox checked and it imported the TG
Correct. I re-verified that on a local system with a great many encrypted TGIDs for both PD & FD on several cities.So it only will not import the full "E", but will a partial... Correct?
OK... I agree with that...Generally, I go ahead & import the 'part time' encrypted channels, and rely on the scanner to ignore it when encryption is collected.
You better believe itSounds like Pro-Scan is worth the 50 dollars
