Sentinel: Sentinel multi-select editing
zebb
Greetings
Now changed over from trx1 to 3600xlt,
In sentinel i can see how to multi select in edit lists which shows up ok as all channels selected (changes colour), I'm trying to multi change alert light so i can change them all at once to desired colour ect, but as soon as i click on one to choose colour it de-selects all the other channels.
any help please. thanks
zebb
I'm not trying to use it on TRx1-E...? Sentinel comes with uniden 3600xlt and works fine.. Just can't multi selection change alert light.
iMONITOR
Silent Key
S.E. Michigan
Ok, you have a UBCD-3600XLT. I was thinking it was one of the old analog scanners, sorry.
RandyKuff
Lorain, Ohio
Set your first alert color block to what you want...
Then while that block is still highlighted, right click on it and copy...
Then place the curser on the block below it... HOLD the left mouse button and drag down till all are highlighted...
Then with the curser in the highlighted area... Right click and Paste...
zebb
Awesome thank you so much.. It's appreciated.
