I wanted to do some LCN searching in Posey Co so I added the Posey Co NXDN system. I had to use Proscan to d/l the system to the scanner. Long story short when I tried to turn on Safe T it said Nothing to scan. Odd since I was in Indiana. When I checked the system on the scanner it had programming from Michigan loaded as SafeT.
Seems either Sentunel or ProScan corrupted my favorites lists on the SD card. I never even messed with the Safe T programming with either software. There were other FLs that had incorrect data also. I did upload the sd card data into Sentinel after adding the Posey System. All I know is something happened someplace.
Sent from my SM-N960U using Tapatalk
