thisguyneedsabeer
- Joined
- May 20, 2020
- Messages
- 112
- Reaction score
- 30
The XPR8400 absolutely does analog. It does DMR, analog, and with the Dynamic Mixed Mode entitlement, will actually do both "simultaneously." I put simultaneously in quotes since analog will only repeat analog, DMR will only repeat DMR, and both can't be used at the same time, i.e. if somebody is talking on DMR, you can't use the analog side of the repeater.
While not as robust as the Quantar, they are great repeaters. And if you're looking for some sort of portability while camping, you aren't going to be dragging a Quantar anywhere. Stick a XPR8400 in a 19" rack pelican case, and portable you go. They aren't exactly lightweight, but still portable enough.
As was said, you can't use DMR on GMRS.
Hmm, ok that changes things, so my current thought is then maybe do the XPR8400 repeater in analog mode.. I've been wanting to pickup a UHF XPR7550e anyway.. and then a XTL2500 for a basestation (to try Simplex house to house). I like staying in the same product family, and am most familiar with Motorola from programming radios at my old EMS department.
