Signal bar response?
JamesBrox
Santa Rosa County, FL
Hey guys. Question. I'm hitting a repeater in the region, a little distant.....but I'm hearing the "Kerchunk". Anyways...I've talked to folks, no problem but sometimes after calling out. I see the RX signal bounce up...like someone's trying to response but no sound. Is that a problem on their end or mine? Thx
WRXU693
DeeEx
New England
What radio?
Could be a signal with a different CTCSS/DCS tone is being received but not opening your speaker because your tone doesn’t match.
FKimble
Newnan, GA
Do you have your radio set to use a receive tone? Not all repeaters send out a tone. Unless there are other repeaters in the area with the same frequency, you are better off not to use a receive tone.
Frank
JamesBrox
Frank
Yes, the info of the repeater on mygmrs. Ok, I'll try using no receive tone.
Thank you
