Simulcast Distortion using a 325p2
Chris0516
Pittsboro, North Carolina
On this page: Simulcast Distortion - The RadioReference Wiki
There is this:
Uniden
P25 Threshold option can be changed after monitoring the Site with Auto to see the best setting for that System to be decoded on
So, if decode is best at 6 in Auto, switch the P25 Decode Threshold for that system to Manual and 6. While 6 isn't a panacea, it's at least a beginning numeric to try starting with, typically up-to 9 in Manual mode will make the biggest difference. Not all scanners allow this ability System/Site specific/individually.
How do I do this?
jeff
St. Augustine, FL
Go to Settings, scroll to P25 Threshold, hit E/Yes, scroll to a level, hit E/Yes. I have mine set at Level 8 and works good on all the simulcast systems I monitor. This is a global setting, you cannot have a different setting for each site. That thread references a time when the 325 didn't save the P25 Threshold settings.
Al1009
Marshfield,MA
From Easier to Read Manual
P25 Threshold this is a hidden setting accessible only by turning off the radio and pressing Hold when you turn the scanner back on.
Scroll to 'P25 Threshold ' and press E/yes.
Scroll to Auto, Level 5-13 and press E/yes.
