Smartnet
rescue161
KE4FHH
Hubert, NC
Just curious as to what flash is in your XTS5000.
100001-000000-7 <------Could this be the flash that's in your radio?
If you were unfortunate to get one of the 123ABC... conventional only radios, then Smartnet won't work without a flash upgrade and if it is a 123ABC... then Motorola won't touch it with a ten-foot pole.
Good luck.
jakedith
Hong Kong
flashcode in my radio was 500008-000400-7 , and the serial 721CDA..... , this can add the Smartnet or not?? Thanks !!
rescue161
KE4FHH
Hubert, NC
Well, that flashcode decodes to the following:
Q806/G806 IMBE / APCO-25 Digital Operation
H14/G114 Digital ID Display
H38/G51 Smartzone Operation
Q173/G173 Smartzone OmniLink Operation
Smartzone is part of this radio, so you don't need to ADD Smartnet. You do need to do as suggested and contact the system admin and have them add you to the system.
There is no other legal way.
rescue161
KE4FHH
Hubert, NC
Smartzone trumps Smartnet.
If a radio does Smartnet, then it will do Conventional.
If a radio does Smartzone, then it will do Smartnet and conventional too.
greenthumb
Colorado DB Administrator
123ABC1234 doesn't necessarily mean that it's a "hot" or "hacked" radio. I've gotten radios back from a Motorola authorized repair center with 123ABC1234 and it just means that the board that holds the serial number was replaced and not properly re-programmed with the serial number. Sent it to Motorola and they fixed the problem.
rescue161
KE4FHH
Hubert, NC
I never said that it was stolen or hacked. Heck I even have a VHF 123ABC1234 here.
What I was getting at is that most, if not all of the 800 MHz units with that serial number had an "IMBE/Conventional only" flashcode, i.e., no trunking.
The only way to flash the XTS5000 is to have Motorola do it and they will refuse to update this radio with that serial number. Plus he'd be forced to affiliate anyway and most system admins would not put a 123ABC1234 radio on their network.
It's all irrelavent anyway as he doesn't have one of those radios.
XTS3000 is another issue and is easily overcome.
