So I got some new hardware, Overkill ?
32dave
Oxford County, Ontario Canada
I have been running my sdr box on a 4th gen Intel i5 and found a Dell R360 for sale $50. Specs are 2X Xeon E5-2620 v3 cpus, 65 gigs of ram also had 2 Broadcom Quad port nics and a LSI sas card. One broadcom card was removed as well as the LSI card. It has 8 2.5 inch slots of which only one is in use (OS). Big problem is lack of usb ports I have ordered a USB 3.0 card. Next is a sound card (currently a usb sound card) and maybe a USB 3.2 card in the future.
What I had to do. Unless you are installing a server os it won't let you, Installed Win11IoT on intel gen 4 i5 drop ssd into server point the boot and thats it . As I said usb is at a premium. It has two in the front two in the back all 2.0 and one usb3.0 internal. I have run an extension from the usb 3.0 to a hub which has 2 rtlsdr plugged in and the two Airspys are plugged into the two back ports any other config and they won't work , Hopefully that will change when the card gets here
Some stats
Intel i5 4690k 16 GB ram, first board MSI Guard Pro Z97 ( fried it overclocking) second board Asus Q87M-E ( cant really overclock)
3 RTL-SDR 1 AirspyR2 average cpu 85% receiving 95-100% scanning 6 channels (TS included as channel) 3 analog 2 DMR 1 P25p2
Intel Xeon E5-2620 v3 64 GB ram Dell r360 board
2 RTL-SDR (1 died after 4.8 years 24/7) 2 AirspyR2 21 channels average cpu 28% mem 18% no change when receiving. I have shut off the paging file as its not needed
Has anybody else done this if so what was your experience like any advice etc and if you have not done this what do you think?
P.S The software is SDRTrunk v61
W8WCA
/usa/oh/cmh EM89kx
So are you saying you installed Windows 11loT on a SSD in the i5 computer then moved the SSD to the Dual CPU Xeon Computer?
That could cause a lot of strange things to happen if that is what you did.
And: I do not know much of Windows 11loT but I think it is limited compared to Windows 11
I would be tempted to just install Windows 10.
Or
Make it a Linux box and install VMWare Workstation on it then make a Windows 11 Virtual Machine on it.
32dave
No issues with the switch just 91 drivers to install ever since Win10 you could just drop drives into different machines I stream to Zello and there is no Linux app for it . From what I have read about 11Iot most of the telemetry is not in it, Don't need a Microsoft account and it doesn't have cpu restrictions. If I could find a version that had enough for internet protection, Zello and the SDRs and software I would use it lol
The server has exsi ( I think thats its name ) installed but its above my knowledge but I have 20 PDFs I have downloaded from Dell and just have to sit down and read them and may go that route
saioke
Windows 11 is finicky with old hardware but I think it'll be fine, as long as it and the rest of your hardware works. Stress test it for a few hours to see if there's any signs of instability. I'd guess that the USB ports you speak of don't work because the chipset made for that thing was never meant to be a consumer machine so there's a lack of chipset drivers on Windows.
I would definitely call it overkill too, can't imagine how much power it would draw if you decide to run it 24/7. If it were me, I'd take out a majority of that RAM because you're never going to use that much, and it'll reduce power consumption on the machine a bit. But that's just me lol.
As for running Zello on Linux, it can be done using WINE. But if you aren't familiar with Linux, I'd advise against using it unless you wanted to learn a new OS.
