I may have left out that I live on the coast.....that's why I'm so concerned. Some storm rain contains saltThe aluminum tube that the mast clamps to also houses the coax connector...and the first 6' section of the antenna...at least on every A-99 that I've ever seen or used. I don't think there's any similar antenna constructed to separate like what you're describing. Only antenna type that sounds like this is a screwdriver type mobile HF antenna that ties together with 3/8-24 thread connectors. You can remove the coil and whip and leave the base behind.
West Marine has it and now after thinking about this, I believe I have some from repairing an underground sprinkler wiring.....put on years ago and no issues yet?If you're worried about water infiltrating the coax connector, find some liquid electrical tape at the auto or marine supply store and apply at least two or three coats. Just cover the lower threads and the plug. Don't fill the tiny hole that's up inside the aluminum tube...it lets moisture drain out from inside. When using LET, be sure to stir it thoroughly to get all the vinyl goo well mixed. The great thing with LET is that it can be removed cleanly with a sharp knife. Most other sealer leaves a horrible mess.
Thanks!Older cans of LET tend to dry up and harden. You may find that you'll need a fresh can. Usually auto parts stores also stock this stuff.
Thanks....just got some!This...
There's another goop to seal taped electric splices I've seen it used to final coat a connector. I forget what its called, it was a fast drying rust colored goop. It totally degrades in sunlight.Thanks....just got some!
I also got some of the silicone self bonding tape!There's another goop to seal taped electric splices I've seen it used to final coat a connector. I forget what its called, it was a fast drying rust colored goop. It totally degrades in sunlight.
