Sony 2010 Outside Antenna & Freqs
paris_tn
What are your top 20 or 30 freqs to monitor on hf? I just got my Sony 2010 out of it's box and listening to it as i type this. I am using the stock antenna that came with it. What would be a good antenna for me to pick up. I have plenty of room outside on a tower. Could an outside antenna hurt my 2010 or overload the front end and damage the receiver?
I am going to put up a scanner beam soon, so i thought i would get something for hf also. Any suggestions?
Thanks,
Tennessee
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Be very careful putting an outside antenna on the 2010. It's very sensitive to static electricity discharges - several folks have blown the front end FETs because of this very problem.
In fact, it's quite likely you won't need a big antenna at all. A standard inverted L of, say 40 foot or so should be all you would need. Our antennas wiki has lots of info on the subject.
Now as to the 'top 20 or 30' freqs - you need to be much more specific? SWBC or utilities?
73s Mike
[edit] Found an article on the hard core dx website that addresses this very issue...
http://www.hard-core-dx.com/nordicdx/antenna/special/2010ant.html
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
To repeat: when you mention 20 or 30 freqs, was that for Broadcast stations or utilities? There's a significant difference. When I mention Broadcast, examples would be R Nederland, VoA, BBC, ect. Utilities - well, that's a much harder one to define. Some common examples would be the Coast Guard, the Global HF System (more correctly known as HF-Global Communications System...), and lots more 73s Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The top 20 or 30 are going to vary depending on your location and whether propagation favors you at the time you are listening - your best bet is to go to the Prime Time Shortwave website (the URL is on the SWL Monitoring wiki page) and download the station lists, which are updated every 4 weeks or so.
A good basic rule - listen above 10 mhz during the day, below that at night.
73s and good listening Mike
