South Jersey Ham DMR Code Plug
ermin
Jacksonville Florida
Also. How do I convert the .rcdx file at http://www.n2jti.net/. I am trying to use the code plug DMR-CODE-PLUGS
MD-380 but the format when I download it is in .RCDX I need it as an RDT file for my MD-380.
Thank you
Ed
w2xq
Burlington County, NJ
The N0GSG DMR Contact Manager Support Page converts DMR codeplugs. Check out the conversion options.
Assuming you are not using a hotspot/Jetpack, in the Philadelphia/Camden area, you want to also look at WR3IRS - Interstate Repeater System for repeaters. Add the Delaware Valley/Philadelphia DMR repeater--the "big talker" in the area--and Waterford to your codeplug. If you are traveling to the Atlantic City/Cape May area add Corbin City as well. Note the talkgroup lineups are all the same.
For Fairless Hills, Trenton and Westampton see http://www.n2jti.net/ for their common talkgroups.
You probably should add tg31360 Tri-State to your codeplug to talk to the local hams. If you are in a hurry, just make up one digital contact, these six 31360 sheets and dump them into one zone list.
HTH.
