Speaker Mic for HT1250 repair
james07731
Monmouth County, New Jersey
I have a shoulder Speaker/Mic for my Motorola HT1250. It doesn't work properly.
The speaker part works. When press the transmitt button, it beeps in the speaker like it should, but it doesn't transmit my voice.
Is this an easy repair? Anyone fix these?
K8TEK
Banned
Ohio
Buy a new one. They are cheap enough.
It could be a number of problems, bad mic element, loose connection, broken pins. It is hard to tell.
davidgcet
yeah we don't even repair them at our shop. by the time you buy a new cord and pay the bench fee you spend as much or more than just getting a new one.
RodStrong
West
I agree. You can get a knockoff for around $15+ or OEM for around $50.
Just get a new one and don't fool with it.
K8TEK
Banned
Ohio
I got a brand new public safety mic for the waris series for $20 on eBay. The guy didn't have it listed correctly so I took it. If you look, you can find deals and be better off.
W2NJS
Washington DC
The described problem may be caused by the channel being set for receive only. It's not normal for an analog HT, which the 1250 is, to make any noise in the speaker when the PTT is pressed.
EMTLJB
Northern NJ
Is it a long continuous tone while the PTT is pressed or a short beep that ends after a second? Does the radio transmit from the on-board PTT or do you experience the same issue?
