stantorres
I have a place near the airport and sometimes I want to listen to air traffic from inside the house and sometimes I want to step out on the porch to watch from there. Thinking about using the External Speaker Jack and the REC jack to drive two speakers, one inside and one outside.
How many watts does the BC780XLT or a BCT15X drive to those audio jacks?
Can I run both a Speco 15 watt horn and a Uniden external speaker at the same time?
Can use a separate volume control for the outside speaker?
Speakers in series add the Ohm's together, and more than 8 ohms can hurt the scanner, right?
If I use the separate jacks, then each is capable of handling 8 ohms separately?
Any suggestions or advice is appreciated.
