Spectra CPS
highcap132
Pine Bluff
This is my first post so please bear with me . I was handed a what Iam starting to think is a white elephant. I was given the job of figuring out how to program our VHF radios. The guy that was doing it quit and would not show anybody how to use the software. The loptop is running win98 which I used several years ago to program the 800mhz STX. When I hooked the Speactra to the system it would turn it on and off several times. I would then get a message the communication failed. I then purchased the updated software when I learned that Win 98 is no longer supported. The software said that it would work on a computer running all the way up to XP. However the disk came with a whole bunch of files that I have no idea what to do with. I then hooked the radio up using the RIB and such and know it will not even do anything just say communcation failed. Does anybobdy have any ideas how to help me with this problem. I do belive that the cables and RIB are good as they did turn the radio on and off attempting to read the radio. thanks in advance for any help and Happy New Year
gary123
You didnt mention whaqt version of cps you are running. I have used COS 3.00.00 (windows version)with no issues . You are describing a comport issue that I have seen with faster computers running older software.
highcap132
Pine Bluff
Thanks gary123 for replying. the CPS is version 5.03. It supports Win OS Vista. With those OS you know the computers are running faster. Do you have any ideas about changing the setting on the com port to make the CPS and the radio talk.
ResQguy
Meh
There is no such thing as Windows CPS for the Spectra, it uses RSS in DOS. Are you talking about an Astro Spectra?
gary123
I have left the comport settings at the windows default.
ResQguy is correct Im so used to programming Astro that I didnt think of the conventional only. Astro soft will not recognise conventional only.
