squelch programming help
mwtn
I'm trying to program some vx-180 radios for fire dept. use and need some info on how to program the squelch settings. The range is from 0-12 but I'm not sure where to set it or why.
I've read the programming on two different radios and one had every channel set to 4.
The other had some set to 4 and others at 1 .
Not sure if it makes any difference but the area they are used in has poor reception (hilly and on the far edge of the county from dispatch)
Marvin
Resqu2
All of our VX180s are set to 4 also. I'm hoping someone will jump on here and explain the difference between the lowest setting and the highest setting.
Axline
Squelch level offset determines how strong of a signal the radio has to receive before it will open the squelch on that channel, and allow traffic. The higher the number the stronger the Rx signal must be. 4-6 is a good range to set this in unless of course your county has terrible comm equipment, then you can set it to a lower number. 4 or 5 would fit best due to the fact that the 180's max output power is 5w so you wouldn't be able to respond to a signal that would only open a channel with the SLOS set at 1.
