APX SRX2200 upgrade
SamMori
I wanna upgrade my model 1.5 srx2200 to 3.5, I have already installed the screen and asked my friend to change the model number to 7BN(I don't know how he changed it)When I finish the part, turn on the radio, the menu, and channel don't show, the main screen still only show time battery scan...
Is this because model 3.5 have a different flash code or individual option? Or because this is an SRX combat radio so the board has some restrictions to upgrade/modify?
GTR8000
NY/NJ Database Guy
BEE00
It's because you did something you weren't supposed to, and used software you're not supposed to have. We don't discuss that software around here. There are other forums where this sort of thing is openly discussed, I'd suggest you find them and post there instead.
Tech21
Why did he change the model number? All you really had to do was change the board to the display board and put it back together. Like GTR8000 said, you done f'd up. Tell your "friend" to delete his software and never touch another radio again for everyone's sake.
GTR8000
NY/NJ Database Guy
BEE00
Not to drag this out, but that's not correct. In order for the front display to function correctly, the model number must be changed from 5xN (1.5) to 6xN (2.5) or 7xN (3.5).
SamMori
Not to drag this out, but that's not correct. For the front display to function correctly, the model number must be changed from 5xN (1.5) to 6xN (2.5) or 7xN (3.5).
It is already changed 7bn still not working
SamMori
I will, I told him he shouldn't have this software
SamMori
I know, also I won't do that again.
GTR8000
NY/NJ Database Guy
BEE00
Could also be a parts mismatch between AN and BN components. The changes between versions are not just cosmetic, the VOCON and RF boards and other internal components are different in the 6000/2200 BN revision from the AN revision.
Funny how you were worried about a repaired radio breaking again, then you went and did this to it. 🤦‍♂️
BryanTheRed
Ø
NC
Did you re-program after the tom foolery? Do you have the channels named? Under Display in Radio Ergonomics, do you have the text size for zone and channel set to 14 and for the top display 8?
SamMori
maybe the screen/keypad metal is an so it does not support the bn model?
I know this makes me look very funny, I'm afraid that it might damage again and I'll have to modify the hardware myself
SamMori
Yes I am, it's not working
GTR8000
NY/NJ Database Guy
BEE00
I would suggest putting the solid back plate back on the radio and hope that you didn't do any permanent harm to it. Enjoy it as a 1.5 and stop messing with software you shouldn't be messing with.
SamMori
I will,thank you for your anwser
