i have done some research and i am not able to find any frequencies for the star and strand transportation bus company
If they use Motorola radios, they will be DMR. If your Uniden scanner is DMR capable, program some of the possible area DMR systems with "ID Search" enabled. If you then lock out the known TGs that are not of interest to you will only hear TGs not presently in the Sentinel download.how would i be able to search for them on my scanner
Huh?How do you program the DEC for the Wells Communication DMR 2?
Huh?
Probably there are no TGs programmed in the Service Type you selected. If you want to see unprogrammed TGs, select "ID Search" mode
