Great topic Steve!
My Current Starcom21 BCD396T settings:
I have tried many digital setting variations on the 396T while monitoring McLean County Starcom21 activity. As for my most recent settings: I’ve reverted back to firmware version 1_10_01. I turned AGC off. I set the P25 Decode Level to 6.
On the occasions when I did choose to use AGC, the settings I used were ones that other people around the country suggested:
P25 Ref Gain: +3
P25 Res Time: -7
I’m interested to hear what settings others have settled on using to monitor Starcom21. If you have BCD396T settings that sound good and/or better, please let us know.
Locking-out trunked sites on the 396T:
Something I noticed is that while monitoring a trunked system with frequencies for different sites entered, you can lockout the control channel frequency that the scanner is locked on to, causing the scanner to search the other freqs in the system for a valid control channel frequency.
While the scanner is scanning your Stacom21 system, hit hold and the scanner will hold on the control channel. Hit L/O to lockout that frequency if you no longer wish to hear traffic from that site. Then resume scanning and the scanner will lock-on to any control channel that it finds, but not the freq(s) that you have locked-out.
This is handy when traveling since you can put all the control channel freqs and talkgroups in one system and then lock and unlock freqs (sites) depending on which sites you wish to allow the scanner to monitor at a given time. For example, while in Bloomington-Normal, I only want to monitor the Watterson Tower (868.400), so I lock out the Congerville (866.850), Leroy (866.875) and Pontiac (867.325) control channel freqs to keep my scanner from accidentally switching to one of the rural towers. When I travel outside Bloomington-Normal, I unlock those freqs (sites) allowing the scanner to find one of the surrounding towers so I can be assured of following the McLean County Sheriff’s Dept talkgroup one of those sites. Unfortunately, this method does not solve the issue of being able to monitor multiple sites at the same time while utilizing one common set of talkgroups.
This trick works on P25 and regular Motorola systems on the 396T. I tried this same method on the 246T and it doesn’t work the same way.
