State of Delaware - P25 Phase 1 System (2024)
u2brent
OAMPT
KRWDPAXKRS1
I had to add location data for the sites to Sentinel manually and write to the radio before the radio actually recognized the system. I use location control and a GPS so this may not apply to you. The RRDB admin needs to add the location coordinates to the site data.
The Sites appear to be correct. The TGID Departments do need location data for the system to work correctly, especially if relying on location control.
maus92
OCMD
The location data was not in the Sentinel download from the RRDB: the lat/long and range data were 0.0. It does show on the site page in the RRDB.
u2brent
OAMPT
KRWDPAXKRS1
Yep, the admin addressed the issue today, so the "nothing to scan/out of range" issue should be corrected, and those willing to wait will get the correction in the next DB pull. Or update the system manually to add loc info for those departments.
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
How’s their testing going for this? Haven’t seen much of an update in a while.
So far, UniTrunker has logged 34 TGs Affilated to, out of which 14 were Channel Grants from the NCCo Site. Most of the TGs are DelDOT, DSP Data, and Mutual Aid. Most Voice Traffic is SCPA and DelDOT TMC. And 140 RID Denials from subscribers on Montgomery Co MD.
chrishoerner
KC3KSJ
Frederica, Delaware
I haven’t monitored much due to lack of change. I did notice some del dot traffic this week on Kent site with Unication. It was a yard channel I’m not sure if it’s full time or not. I Did not confirm if more voice channels haven been added to Kent site yet. I will run decoder this weekend on Kent site.
chrishoerner
KC3KSJ
Frederica, Delaware
At what point would corrective action be needed with the interfering stations? Should control channel be changed or does it even matter? It doesn’t seem to bother the system does it, just denies and moves on. I guess it could be interesting if there was a matching talkgroup.
Audiodave1
Chadds Ford, PA
Could these could be mobile units driving N/S just leaving their radios on thru DE? Extradition details, prisoner transports etc. ?
motorcoachdoug
Silver Spring, MD
That seems to be a lot of Montgomery County units over in DE if it rejected that many. What county was the majority of the rejected radio units?
trailhiker73
Delaware
Here are the "latest" minutes from the Statewide Interoperability Council meeting.
  • 78568_Minutes-Draft.pdf
chrishoerner
KC3KSJ
Frederica, Delaware
That portion of Maryland is pretty self sufficiency no reason to leave to come all the way here on regular basis. I think it’s skip over the bay when conditions are right. I’m curious what level of interference warrants corrective action.
maus92
OCMD
It's not really interference. Radios from Montgomery County are requesting access to the Delaware system and are being denied. It could be officers traveling and losing contact with their home system. The radios interpret this as a change in control channels and start hunting for another. Depending on how the subscriber radios are programmed, some alternate control channels on the MC system *may* be some cchs that are used by Delaware.
Hbright
I'm gonna be in Sussex Co this week, what is the current control channel for their new P25 site? I'd like to monitor.
de784
Delaware
What's listed in the database is correct. So far it is just animal welfare
magiclightman
Someone mentioned a few posts right before we started seeing the system online that they heard that the state and mot were going to flash any APX that didnt have the correct flashcode as they built out the codeplugs. I assumed that meant the EOL ones. We will see soon for sure.
That is correct
magiclightman
For those who have access to the calls platform, I've setup a feed to ingest the new system any any TGs that appear so we have a easily accessible record of TGs for monitoring.
Also for a quick reference if anyone would like, I did an excel sheet with the current decimal TGIDs on the Type 2 system and their "predicted" P25 TGID counterpart based on the x16 logic that was pointed out earlier on.
  • SOD P25 TGID Predictions - trs_tg_411.pdf
magiclightman
After the last week of monitoring sounds like the following can be confirmed:
1369 N-AREA10 D Bear Yard - Area 10
1371 N-AREA11 D Kiamensi Yard - Area 11
1373 N-AREA12 D Talley Yard - Area 12
1359 N-AREA14 D Newark Yard - Area 14
1357 N-AREA14 D Newark Yard - Area 14
Also looks like maybe 1093 which is SW-SPCA got fat fingered as 1903 into the DB when it was entered.
Saw some activity on 317 N-M-1 D Expressways Maintenance Dispatch 1 which would track with the other DelDot TGs but would want to confirm this first
