State Police
MSP121
Maryland
I Will Be Travelling Through Arkansas In A Few Months And Had A Question About Monitoring Asp. I Will Be Using A Pro-96, I Will Be Passing Through Troops D,a,j, And H. Can I Program All Of The Sights For Those Troops In The Same Bank Or Do I Have To Program Them Into Separate Banks.
bpckty1
You will need a scanner such as the R/S Pro-96 or the Uniden BCT396 to receive ASP. They are using a digital system called AWIN. See the Arkansas Database for more information.
safetyobc
South Arkansas
yes, I think that a Pro-96 will allow you to do that. It will monitor each control channel for traffic, even if you are in range of more than 1 at a time.
Have a safe trip.
bpckty1
On my last trip to LR, I put the AWIN control freqs for the troops along I-30 (A/K/G/E (Pine Bluff) and statewide), and the tgs in separate folders for each troop, and one for misc tgs, especially in the LR area (UALR, LR specific tgs, etc.).
I also put the AWIN LR control freqs and tgs separately in another bank since I was in the LR area and didn't want to have confusion when, occasionally, for example, a Troop G tg slipped in.
And, ScanningArkansas.com, is a good reference for other agencies, such as the Highway Patrol, a separate state agency that works the highways, primarily truck enforcement.
When going through Troop A, don't forget to monitor the LR and Jacksonville TGs, since you may be on a road in their jurisdiction, as well as the UAMS TRS, and, if you venture a bit south, the Hot Springs TRS. Plus, the ITAC conventional frequencies. They are used in the LR area for various reasons: medical, chit-chat, etc.
tallen74
Beebe, AR
If you like I can send you my USD file for AWIN (Ark State Police, et al) Little Rock PD, NLR PD, Sherwood PD as well as all of the above fire departments.
I also have the various counties along I's 30 and 40 that I can send you also.
vacrx
tallen74, I'll be drving thru Arkansas also on my way to Texas from Virgina, coming in from the Memphis Tn area and out thru Texarkana, do you files for that whole stretch of interstate? Thanks.
tallen74
Beebe, AR
Arkansas USD Files
Here are the files for the Arkansas State Police as well as several counties that are currently using AWIN. I don't have things like emergency management programmed because I don't listen to them very often. I also included the Little Rock TRS as well as the county files by region. ARRegionEA is counties in the eastern part of Arkansas, SW is southwest and so forth.
If you have any questions please don't hesitate to ask.
Also, have you checked the ScanningArkansas.com website. This is a VERY well constructed site that has every county in Arkansas with Police, Fire, EMS and quite a lot of other info ready for download. It is administered by a member of the ASP who is very involved/knowledgable in scanning. There is a map of the different state police troops so you will know which troop you are travelling through. Give it a look.
Hope this helps!
  • ARRegionEA.usd
  • ARRegionSW.usd
  • AWIN.usd
  • LittleRockTRS.usd
  • AWINCounties.usd
