Anyone here from stearns county? Looking for some help with my 396t.
After researching around here and trying different things, seems to be better. Looking for optimum settings for my 396t. Suggestions?
I have all the control channels from St cloud area and enfield. I live by Clearwater. Some of the transmissions are choppy. Presuming it's from one of the distant towers. I pick up enfield real good here. From what i can tell, St cloud is 24000 series and wright county I'm presuming is 25000 series, but cannot confirm this. I just found the hidden menus to make adjustments so will try those to see if I can tweak this a bit more. One question is since minnesota is not a true P25 system, when programming a new bank, i use motorola, then 800 MHz standard instead of P25, correct? Thanks for the help.
Still playing with it. Reprogrammed. Now am only picking up enfield tower. Still deaf on St cloud, kimball, which isn't to far from me. Is anyone picking up St cloud past few days?
Have you thought about doing a full reset on the scanner and reprogramming?
Already did that. Unless there is a different method, I held the 3 buttons while turning on. Still no problem hearing enfield, which only at 1 freq, and it's an primary only. No alternate list on RR. Are you folks putting just the primary and alternate in the freq's list or are you including those other freq's? Have read you only need the CC freq's unless none are listed.
