Office is currently un-reachable by phone (due to COVID-19). Below is an email reply I received from a city building official. I didn't think Amateur radio was "private radio", feel like this doesn't quite apply. Thoughts? :
"Good Afternoon Philip
I included below the following ordinance requirements relative to the installation/construction of a radio antennae for private communications. The specific section is 28.00 of the Zoning Ordinance. Please let us know if you have any questions. I also included our Building Official on this email.
Thank you
Chris
H. Satellite dish antennas and other television and radio antennas/receivers may be permitted as accessory structures in any zoning district, subject to the following provisions:
1. A satellite dish antenna that is designed to receive direct satellite service, including direct-to-home satellite service, that is one meter or less in diameter shall be permitted without a zoning compliance permit, unless it is attached to a mast of greater than 12 feet in height. If the mast to which it is attached exceeds 12 feet in height, then special approval land use by the Planning Commission under Article 25 shall be required;
2. A satellite dish antenna that is designed to receive video programming services via multi- point distribution services, including multichannel multi-point distribution services, instruction television fixed services and local multipoint services and that is one meter or less in diameter or diagonal measurement shall be permitted without a zoning compliance permit, unless it is attached to a mast of greater than 12 feet in height. If the mast to which it is attached exceeds 12 feet in height, then special approval land use by the Planning Commission under Article 25 shall be required;
3. A conforming commercial earth station shall be permitted without a zoning compliance permit;
4. An antenna that is designed to receive private radio or television broadcast signals which is less than 12 feet in height when installed shall be permitted without a zoning compliance permit. If the antenna exceeds 12 feet in height, then special approval land use by the Planning Commission under Article 25 shall be required. Such a structure shall not, however, be erected so as to injure the roof covering, and when removed from the roof, the roof covering shall be repaired to maintain weather and water tightness. The installation of any antenna structure mounted on the roof of a building shall not be erected nearer to the lot line than the total height of the antenna structure above the roof, nor shall such antenna structure be erected near electric power lines or encroach upon any street or other public space;
5. Satellite earth stations more than one meter in diameter located in a residential district shall require special land use approval by the Planning Commission under Article 25;
6. Satellite earth stations more than two meters in diameter located in an area where commercial or industrial uses are generally permitted shall require special approval land use by the Planning Commission under Article 25;
7. An antenna that is designed to receive private radio or television broadcast signals shall require a special approval land use by the Planning Commission under Article 25 if the height exceeds 12 feet;
8. An antenna of any type or size which is to be erected on a structure that is located in a district that is listed or eligible to be listed in the National Register of Historic Places shall require special approval land use by the Planning Commission under Article 25;
9. Any approved structure shall be subject to compliance with all applicable regulations, including but not limited to the requirements under the BOCA Building Code;
10. The Zoning Board of Appeals may modify the requirements of this section as authorized in section 30.02C5.
The application for a special approval land use or variance shall include construction drawings showing the proposed method of installation, including details on foundations and anchoring, and a site plan or plot plan showing the proposed location. Any structure covered by this section shall not be located in any front or required side yard setback."
