Sticky Thread For MilAir IX (2014)
mdmonitor
NOTAM for Iraq
Guys,
FYI:
FOR IMMEDIATE RELEASE
August 8, 2014
Contact: Kristie M. Greco
Phone: (202) 267-3883
New Notice to Airmen Issued for Iraq
The Federal Aviation Administration today issued a new Notice-To-Airmen (NOTAM) restricting US operators from flying in the airspace above Iraq due to the hazardous situation created by the armed conflict. The new NOTAM supersedes previous FAA guidance for this airspace.
The NOTAM reads:
!FDC 4/1621 ZZZ SECURITY …IRAQ … POTENTIALLY HAZARDOUS SITUATION—IRAQ AIRSPACE
DUE TO THE POTENTIALLY HAZARDOUS SITUATION CREATED BY THE ARMED CONFLICT BETWEEN MILITANTS ASSOCIATED WITH THE ISLAMIC STATE IN IRAQ AND THE LEVANT AND IRAQI SECURITY FORCES AND THEIR ALLIES, ALL FLIGHT OPERATIONS IN THE BAGHDAD FLIGHT INFORMATION REGION (ORBB) BY THE PERSONS DESCRIBED IN PARAGRAPH A BELOW ARE PROHIBITED UNTIL FURTHER ADVISED.
A. APPLICABILITY. THIS NOTAM APPLIES TO: ALL U.S. AIR CARRIERS AND COMMERCIAL OPERATORS; ALL PERSONS EXERCISING THE PRIVILEGES OF AN AIRMAN CERTIFICATE ISSUED BY THE FAA, EXCEPT SUCH PERSONS OPERATING U.S.-REGISTERED AIRCRAFT FOR A FOREIGN AIR CARRIER; AND ALL OPERATORS OF AIRCRAFT REGISTERED IN THE UNITED STATES, EXCEPT WHERE THE OPERATOR OF SUCH AIRCRAFT IS A FOREIGN AIR CARRIER.
B. PERMITTED OPERATIONS. THIS NOTAM DOES NOT PROHIBIT PERSONS DESCRIBED IN PARAGRAPH A FROM CONDUCTING FLIGHT OPERATIONS WITHIN THE BAGHDAD FLIGHT INFORMATION REGION (ORBB) WHEN SUCH OPERATIONS ARE AUTHORIZED EITHER BY ANOTHER AGENCY OF THE UNITED STATES GOVERNMENT WITH THE APPROVAL OF THE FAA OR BY A DEVIATION, EXEMPTION, OR OTHER AUTHORIZATION ISSUED BY THE ADMINISTRATOR. OPERATORS SHOULD CALL THE FAA WASHINGTON OPERATIONS CENTER AT 202-267-3333 FOR FAA AUTHORIZATION OF OPERATIONS.
C. EMERGENCY SITUATIONS. IN AN EMERGENCY THAT REQUIRES IMMEDIATE DECISION AND ACTION FOR THE SAFETY OF THE FLIGHT, THE PILOT IN COMMAND OF AN AIRCRAFT MAY DEVIATE FROM THIS NOTAM TO THE EXTENT REQUIRED BY THAT EMERGENCY.
THE PROHIBITION ON OPERATIONS IN THE AIRSPACE SPECIFIED IN THIS NOTAM AND THE ASSOCIATED JUSTIFICATION FOR THIS SPECIAL NOTICE WILL BE RE-EVALUATED BY 31 DEC 2014.
freqhopping
Well this is different.
DC KC-135 57-1479 is using the callsign VENUS23.
This morning I picked up a ground-based mode-S/ADS-B signal.
ADFC2C at 375ft N38.9223 W77.20514 ID was MTR1TEST
The location is the Mitre office in Tysons Corner.
FIREBOX2914
MARYLAND
VENUS23 is odd. Maybe its because its transitioning to somewhere and taking passengers?
Also:
FELON 32 C-130H 93-1039 700th AS/90th AW Dobbins AFB
BISON 85 C-130H 91-9142 328th AS/914th AW Niagara Falls NY
RCH 165 C-17A 04-4136 6th AS/305th AMW McGuire AFB
RCH 978 C-5A 70-0760 167th AS WV ANG, Charleston, WV
are flying around on ADS-B
mdmonitor
Logs, 8 Aug
ACY-Atlantic City NJ (KACY)
ADW- Andrews AFB MD (KADW)
BW- Bay Watch-NAS PAX Area Advisory Control
DAA- Davison AAF, Ft Belvoir VA (KDAA)
DCA- Reagan National Airport/CGAS Washington, Wash DC (KDCA)
DOV- Dover AFB DE (KDOV)
GK- Giantkiller (FACSFAC, Virginia Capes)
LFI- Langley AFB VA (KLFI)
MTN-Martin State Airport, Baltimore (KMTN)
NGTF-Northrop-Grumman Test Facility, Baltimore (KBWI)
NTPS- Naval Test Pilot School, PAX
PAX-NAS Patuxent River MD (KNHK)
PTC- Potomac Area TRACON
WRI-Joint Base-McGuire-Dix-Lakehurst NJ (KWRI)
ZBW-Boston ARTCC
ZDC- Washington ARTCC
ZNY- New York ARTCC
1. VHF/UHF: ((Times are EDT))
((Some acft idents from local Mode-S collection))
0733- Reach 1816 (C-17 # 09-9192 437th AMW Charleston AFB SC)-land at ADW.
0850- Two unid acft (using calls Target & Fighter)-w/BW (256.5) for ACM training. Mode-S shows T-6B # 165967 & T-38C # 15-8200 (NTPS PAX) active in this time period. Prob T-6B is Target & T-38C is Fighter..
1110- Army 1053 (UC-35 # 00-1053)-land at ADW.
1115- Jenna 209 (FBI Manassas VA)- depart Manassas
1118- Tester 00 (F-18, NTPS PAX)-w/BW (256.5) w/Tester 14 (T-38C # 67-4943 NTPS PAX) in ACM evaluation flight. Tester 14 RTB at 1135.
1120- Hound 91 (C-146A 27SOW/524SOS Cannon AFB NM)-land at ADW
1121- PAT 611 (C-12U # 84-0176 OSACOM)-land at ADW.
1139- Acft 210 (unid--tail code missed-- PAX)-w/PAX approach (281.8) for landing at PAX.
1333- SD 536 (EA-6B # 159909 ICAP III Test Bed VX-23 PAX)-w/PAX approach (121.0) for permission for a couple patterns for test purposes.
2. HF: ((Times UTC, Freqs KHz))
09025.0 ADW (HF-GCS Andrews AFB MD): 1449- USB/ALE calling 23140 (US Army helo)
Ron (mdmonitor1@verizon.net)
Baltimore MD (390747N 763711W)
VHF/UHF: BC-895XLT/RS Pro-2045 w/Diamond D-130J discone
HF: Icom R75 & Sangean ATS 909 w/45-ft PAR EF-SWL
FIREBOX2914
MARYLAND
Don't think you have the tail number correct, last 70 is 0467. Maybe you mean 70-0460 that used to be at Stewart and is now with the 167th at Martinsburg.
Your correct. Fat Fingers was 70-0460. I totally got that wrong.
freqhopping
Anybody else picking up the ELT on 243.0? Really strong for me on that freq, just barely coming through open squelch on 121.5.
freqhopping
Been a while since I've seen one of these.
C-32B 02-5001 DEMUR08 heading north, north of Richmond. Could be heading into Andrews.
1022- with approach 128.35, looking for 19R at Andrews.
freqhopping
CTM2014 French Air Force A400 0008 has departed Dulles it looks like. 133.85
Heading west.
Only one log entry hit on it yesterday at about 1515.
mdmonitor
High Flyer
Guys,
1328- Trident 38 (unid, PAX)-w/BW (270.8) request handoff coordination w/GK then cleared to depart from Seahawk (???) at FL450. At 1335 w/GK (118.125) check in at FL450 request block FL510-600
Anyone got anything on their Mode-S boxes?
mdmonitor
1522 EDT- Dragnet ??? (E-3B # 77-0356 552 ACW Tinker AFB OK)-working w/Bandit flt (4 X F-22s LFI) & T-Bolt flt (F-22s 149th FA VA ANG LFI) on GK discrete (236.55)
NOTE: Mode-S showing ATC callsign Sentry 61H so maybe it's Dragnet Hotel.
freqhopping
I logged something with the hex code 001234. Not sure what it was. My planeplotter log doesn't record altitude so no idea if that was the high flyer.
My log from 0000 UTC
00000000 167951
72119 09-72119
155481 155481
158198 0157
163838 4670
165159 0000
02-4452 0000 FEST
10-0257 ALLIED1
65-10473 0153
70-1576 0151
79-0434 0000
82-0007 3150
84-0176 0000
86-0030 0000
91-0513 0000
94-1569 0000
98-0002 0000
N159CM DHS
N208EB 0000 FBI
N411CP FBI
N539MY N539MY FBI
N636CP CAP
N6977A DHS
N844LC DHS3
N916WR 0000 FBI
N981GT FBI
@@@@@@@@ 158198
ADDAM3 166060
AF2 98-0002
AF2 98-0002
ALLIED1 10-0257
ALLIED1 10-0257
BACKY13 61-0294
BACKY14 62-3509
BOXER 02-0202
BOXER81 94-1570
BOXR999 94-1569
CNV4644 165831
CNV4902 166696
E05701 10-5701
E91444 59-1444
EASY40 165740
GHOST13 57-1440
GOTOFMS 164410
HOIST99 79-0433
MAINE99 59-1488
N859JA N859JA FBI
NAV7A838 163838
OPEC13 83-0079
PACER01 84-0137
PAT528 10-0258
PAT661 86-0088
PAT756 84-0485
PAT78 04-1778
PAT843 10-0256
R01052 00-1052
R01053 00-1053
R1944 97-1944
R24380 84-24380
RBY301 N745VA
RCH1107 62-3573
RCH439T 06-6167
RCH507 09-9207
RCH563 05-5140
RCH789 07-7182
RCH864 02-1100
RCH972 99-0165
ROCCO81 60-0366
SAM614 99-0004
SAM729 86-0206
SAM765 98-0002
SAM799 86-0204
SAM906 86-0202
SCORE55 160627
SNTRY61H 77-0356
SPUR40 58-0084
SPUR41 58-0010
STEEL64 59-1468
TBIRD14 95-0102
TOPCAT4 62-3544
VENU23 86-0203
VENUS21 86-0201
VM200 166378
VM374 166374
VV400 166376
VVAX997 164997
1833-SCORE50 C-130 160627 with Pax approach 362.6
1836-LIGHTNING62 flight of two at 16500ft south of Wallops, RTB 354.8
BM82557
Berkeley Co WV
I have following freqs for KMRB:
124.3 tower
126.825 Potomac approach
297.9 Pikeside CP
Are these valid?
124.3/233.7 tower and 297.9 167th AW CP (Pikeside Control) are accurate. Don't usually have 126.825 in my rotation but it is Potomac (ground side at -50db at my location).
mdmonitor
Logs, 11 Aug
ZBW-Boston ARTCC
ZNY- New York ARTCC
0730- SAM 765 (C-32A # 98-0002, 1st AS ADW)-depart ADW.
0849- Goth 61 (E-6B # 164410 VQ-4 Det PAX)-calling Huntress (364.2) w/no response.
1155- Score 30 (prob P-8 Poseidon # 167951 VX-20 PAX)-w/BW (355.8)
1203- Marine 374 (UC-35D # 166374 MAW-4 ADW)-land at ADW.
1226- SAM 799 (C-20B # 86-0204 99th AS ADW)-depart ADW.
1230- Reach 653 (C-17# 05-5140 AFRC 452 AMW/729 AS March AFB CA.
1232- Acft 1842 (US Army)-w/ZDC Cape Charles (132.55) cleared to Felker AAF VA.
1328- Trident 38 (unid, PAX)-w/BW (270.8) request handoff coordination w/GK then cleared to depart from Seahawk (???) at FL450. At 1335 w/GK (118.125) check in at FL450 request block FL510-600.
1338- Pacer 01 (C-21A # 84-0137 457th AS ADW)-patterns at ADW.
1350- SAM 792 (prob C-20B # 86-0203 99th AS ADW)-depart ADW. At 1352 w/SAM CP (141.55) reporting departure at 1740Z and ETA destination 2115Z w/no DV on board. NOTE: Unusual to use SAM callsign w/no DV on board. Mode-S showing ATC callsign as Venus 23.
1313- PAT 0176 (C-121T # 84-0176 OSACOM/Det 13 Phillips AAF MD)-land at Phillips AAF (126.15)
1436- PAT 661 (C-12F # 86-0088 FL ARNG OSACOM DET-8 St Augustine FL- w/Griffin CP (141.55) w/inbound msg. Departs ADW at 1532 then w/ZDC Calvert (133.9).
1442- Boxer 81 (C-38A # 94-1570 201st AS DC ANG ADW)-patterns at ADW.
1522- Dragnet ??? (E-3B # 77-0356 552 ACW Tinker AFB OK)-working w/Bandit flt (4 X F-22s LFI) & T-Bolt flt (F-22s 149th FA VA ANG LFI) on GK discrete (236.55). NOTE: Mode-S showing ATC callsign Sentry 61H so maybe it's Dragnet Hotel.
1528- Energy 51 (N6451D BE-200 Dept of Energy ADW)-depart ADW.
1534- Navy TP 17 (T-38C # 15-1579 NTPS PAX()-w/PAX Approach (250.3)
1542- Evac 19444 (KC-135R # 59-1444 OH ANG 121st AMW Rickenbacker Intn'l Columbus OH)-land at ADW.
1345- Air Force 2 (C-32A # 98-0002 1st AS ADW)-land at ADW.
1354- Unid acft (no call noted--poss T-6B # 166060 NTPS PAX)-on PAX range discrete (277.05) w/PIREP.
1620- Mussel 06 (UH-1 1st Helo Sqdn ADW)-w/Wash Helo (134.35)
1622- Irony 07 (C-182 DOV Flying Club)-patterns at DOV (135.15)
1625- Mussel 13 (UH-1 1st Helo Sqdn ADW)-land at ADW--had to wait 15 mins while VP entourage cleared the area.
15867.0 N17 (USCG HC-144A #2317 ALC Elizabeth City NC): 2000 USB/ALE sounding.
