What are the storm chasers using this spring/summer for frequencies up around Loveland, Ft. Collins to Wyoming border, Greeley, out east toward Yuma, Sterling area?
Thanks Jim, Do you have another map and frequencies out by Morgan county out east or can you send me the link that has all the freq's on it and counties? The one you posted was great. I been looking but the ones I found was many years ago like 2005 and 2010 and I'm sure they were out dated. Does counties have car to car also? Thank you very much!Here's a map from 2016 that should be reasonably accurate. For the counties farther east look in the data base for the ARES frequencies for that county. Skywarn frequencies are the ARES group for each county. Weather Nets are now run by the individual ARES groups. Many years ago the Denver Skywarn group used the 146.94 repeater but as participation changed, county ARES groups in each county stepped up to run weather nets. Hope that helps!
I would suggest looking in a repeater guide or the RR Data Base for ARES frequencies for those counties. You might also look for listings for the ARES group in each county. The only map I had was for the Front Range groups.Thanks Jim, Do you have another map and frequencies out by Morgan county out east or can you send me the link that has all the freq's on it and counties? The one you posted was great. I been looking but the ones I found was many years ago like 2005 and 2010 and I'm sure they were out dated. Does counties have car to car also? Thank you very much!
Does anyone know what Cheyenne, Wyoming use for frequencies on Skywarn?
You may have to do some research for the PL tones. I looked and had trouble finding an accurate listing of the repeaters and PL tones.... Good luck!Thank you Jim!
Neither if you are only listening. If you're using a scanner that accepts PL and want to, use the output tone.Do I put in the input or output PL Tones?
