Strange things
rescue1017
Leonard , Texas
Anyone hearing a fire dept the last 2 days from somewhere else ? I know they are far away because the tone out times are an hour different from us the feq is 46.4600 they have been comming in pretty good I did hear one unit responding to somewhere on the beltway
thadood
Texas
Atmospheric Bounce maybe ??? im about 80 miles south of houston and every so often ill here all of the starnet system from here and the HFD and HPD operations for about 30 minutes , somtimes its at 3 am and somtimes its a few minutes before the sun comes up !
DELCOLHFC
S.E. PA
46.46 could be Baltimore County MD, it's a patch to their dispatch and ops TG's. I listen to them regularly from home just outside of Philly. It's a pretty strong signal and they do run alot of jobs on 'the beltway'.
WX5JCH
Banned
Elk City, Oklahoma
I was picking up a lot of lowband skip yesterday from Missouri 42 mhz and in the 46 mhz range. Lasted almost all day.
Texas
Might be wrong, but I believe it is skip caused by the E layer of the Ionosphere. If Im right, that means the skip will not be heard at night because the E and D layers go away leaving only the F layer.
rescue1017
Leonard , Texas
I have enjoyed listening to them I was just wondering because they ran call after call after call most of the day Friday and then on Saturday I like it is something different to listen to other than Fannin county all the time but the strange thing was that I dont have my outside antenna hooked up it was the antenna that came with my scanner
nd5y
Wichita Falls, TX
You're wrong. You can hear sporadic E skip lots of times at night. One of the peak times it tends to happen is around 8 - 10 PM local time.
Sporadic E skip has nothing to do with the changes in the D & F layers when the sun sets.
k3td
Wake Forest, NC
Spradic E skip is propagation that is caused by ionized layers within the E region of the ionosphere. It is called "sporadic" because it cannot be predicted the same way that F layer skip can be predicted during the sunspot cycle.
Sporadic E can happen any time of the day or night and any day of the year anywhere in the sunspot cycle. It is most common from about mid-May to mid-July, with a smaller "season" in December. It most often affects frequencies from about 25 to 150 MHz, although it is less common as the frequency increases. Sporadic E comes and goes with little notice. Signals tend to be very loud and sound like "locals". It can last a few minutes or several hours.
It is "magic" !!!
Bonham has a license for 46.46, Ellis Co. has a 46MHZ license, But the Skip had been Incredible lately, it could be out of Alaska and blowing your doors off.
Al42 said:
The beltway is most likely the Washington, DC area.
Unless you're near Houston - in which case it is most likely Beltway 8 which is a giant toll road encircling the greater Houston area. But with skip ... who knows?
-rick
scanfan03
Houston, Texas
-rick
I don't know of any fire department in the Houston area still on VHF low.
I don't see anything on 46.46 but here are a few ... don't know how many are still active ...
Code:
PL     Freq              Description
       33.480           FIRE Champions Area VFD (using Cypress Creek UHF)
127.3  33.520          *FIRE Community (Alief) VFD Primary (simulcast STAR-NET trunk 11856,453.8375)
192.8  33.620          *FIRE Atascocita VFD Primary (STAR-Net trunk 20944)
192.8  33.640          *FIRE Little York VFD Primary (link to 453.4625 MHz)
192.8  33.700           FIRE Command
192.8  33.720           FIRE Eastex Fwy
192.8  33.740          *FIRE Westlake VFD Ch.A Primary (simulcast STAR-NET trunk 15888)(WXT759 expired)
192.8  33.760           FIRE East Mount Houston (not licensed)
192.8  33.780/33.460   *FIRE Cypress Creek VFD (linked to 453.300)
192.8  33.820          *FIRE Northwest VFD (using UHF 453.575)
192.8  33.860          *FIRE Eastex Fwy, Aldine, Westfield Rd VFD (HCESD-1) Dispatch (moved to 453.625 MHz)
192.8  33.900           FIRE Ponderosa VFD (using Cypress Creek UHF)
192.8  33.940           FIRE Champions Area VFD (using Cypress Creek UHF)
192.8? 33.960/33.420    FIRE Atascocita VFD
192.8  33.980          *FIRE Mutual Aid-Harris County, Cy-Fair VFD Ch.6
107.2  35.020/154.600  *BUSINESS Drive-Thru McDonald's Fairmont
 88.5  35.880/151.745  *BUSINESS Drive-Thu Sonic Woodridge/I-45
       37.140           CITY of Splendora
       37.180           CITY of La Porte
       37.180           CITY of Waller Public Works
       37.420           CITY of La Porte
       37.900           COUNTY of Brazoria-Civil Defense (KNBY520 expired)
       40.100           AVIATION Conroe National Guard Helicopter Maintenance Facility
       41.000          *AVIATION Ellington National Guard Helicopters & Command Post "TAC-1"
       45.120           CITY of Jacinto City
       45.160           CITY of Richmond
       45.280/46.520    CITY of Pearland (emergeny management)
 none  45.320          *FIRE Richmond (repeats STAR-Net trunk 4816)
       45.440           MEDICAL Montgomery County Hospital District (data)
       45.600           CITY of Richmond
146.2  46.060/46.360   *FIRE Richmond (STAR-Net trunk 4816)-Rosenberg using dispatcher repeat of TG 4304
       46.080          dCITY of Alvin EMS tone-out
       46.120           FIRE Rosharon VFD
       46.140          *FIRE Brazoria County
       46.160/46.500    FIRE/EMS Richwood
       46.160           FIRE Richmond (STAR-Net trunk 4816)
       46.200           FIRE Clute
       46.220           FIRE Richmond (STAR-Net trunk 4816)
       46.240           FIRE Iowa Colony VFD
       46.260           FIRE Oyster Creek VFD
       46.280           FIRE Manvel VFD
       46.360           FIRE Liverpool VFD
203.5  46.380          *FIRE Angleton
       46.420           CITY of Pearland (fire or EOC)
       46.440          *FIRE Beasley
       46.480           FIRE Old Ocean VFD (license WPAJ228 expired)
Freqs above courtesy of Myle's list.
Of course, it would be very cool if this was in fact coming from the DC area.
-rick
rescue1017
Leonard , Texas
Well I finally heard and address on a call this weekend and it was at the beltway hotel so I looked it up and it was in fact around Washington DC so now I know who I am hearing during the day
VintageJon
OK, I'm convinced! I've got to put up a discone and program the Pro91 for these freqs!
I love skip!
73's
Jon
