Styker static high power meter
Saywhen
Hello Im having issues with my styker sr-447hpc2. It send and receives transmission however the power meter stays pegged at least 3/4 of the way up the meter and the static doesn’t go away until you are 3/4 or father up the squelch. If anyone has any ideas they would be greatly appreciated
jonwienke
More Info Coming Soon!
VA
It's more likely to be RFI or RF gain set too high than a problem with the radio.
Saywhen
I was able to adjust the static out by lowering the rf gain. So the two cbs (a galaxy and cobra) I had before my styker I would run the rf and mic gain full blast and adjust the static out with the squelch it would only take about a 1/4 of the squelch knob to adjust out the static. So I guess my question is does it matter which way you adjust the static out.
jonwienke
VA
If you can find the source of the static and eliminate it (unplugging a bad USB wall wart, etc), thats the best option.
