Here is a picture during a test-fit while installing a BC-996T scanner in my WRX. Ignore the unfinished edges for now!
The brackets behind the panel are ISO sized, but the opening plate is not. Had to remove 5mm of materal from each side. I'll post more pics later. Will note how the Uniden actually bleeds over into the space for the unit below too. Fortunately the cd player has a small face and allowed the Uniden to hook over the front edge of it (the cd face comes off).
Electronics were super easy to hook up. Power. GPS. Splitter on AM/FM antenna. No problems. I was replacing a Uniden 780, so really the power connector just changed. I only pulled RX from the GPS bus in the car. There is a Kenwood D700 which has full access to it, tho I don't really use it.
