Stormchaser_35 said:
also Ground the antenna well, I use a copper 8' grounding rod
It may be a good idea to tie that ground into the building ground as well, it helps cut down on voltage differences between grounds and in the unlikely event of a lightning strike it helps to ensure there is a solid path to ground. Use good quality connector seal to keep your connectors water tight, use a good quality corrosion inhibitor on your ground connections and use a large guage wire for ground, such as #8 solid copper. keep your ground connections as short as you can, use "drip loops" where the coax enters the house, this keeps water from running down the coax and into the wall. Caulk the hole where the coax enters and if you can angle your entry hole up, this also helps keep water from getting inside the wal in case of a leak. Don't be tempted to use plumbing strap or some other flexible strap to mount the pole to the wall, use solid, galvanized steel brackets designed for that use. If you want to save a few dollars on mast poles and are going to be using a light weight antenna you can get chain link fence top rails for about half the cost of antenna mast. These are not suitable for tall masts or heavy or high wind load antennas. Be sure to use rust resistant hardware, stainless or galvanized steel. DO NOT substitute heavy duty lag bolts with wood screws, use the large lag bolts included with your mounting hardware. I have seen far too many antennas installed using sheetrock screws in place of more suited hardware that have came down in the wind. Zip ties are not suitable for attaching coax because the zip ties can crush the coax if pulled too tightly. Use a more flexiable strap to attach the coax to the mast and leave some slack at the antenna to allow for thermal exspansion and other movement that may occur. its also a good idea to install a discharge tube type grounding point at the base of the mast to discharge any static buildup or energy bleedoff from lightning strikes and such. just as a safety precaution, if you use more than one section of mast pole it may be a good idea to drill a small hole at the joint and put a bolt thru the joint to keep the poles together. I have seen gusts of wind pull mast pole sections apart because the antenna on top made a great sail. I am sure there is more, and if I can think of anything else i will add to it.
