Synthszr unlocked
harryshute
Edmonton, Alberta, CANADA
I have an 800 MHz (806-870 MHz) LPE 200 radio that displays the following when it is turned on ... "SYNTHSZR UNLOCKED". I have been unable to find anything here on RR to assist with this problem. Conventional frequencies work fine but no Edacs talkgroups will work.
I have programmed in an Edacs system with frequencies in the range of 866-869 MHz. This is where this problem happens although conventional frequencies in this range do work.
I have programmed this same personality file on other LPE 200 radios and it works fine.
The radio has the following radiocode and dsp files ... RadioCode P1R16C00.BIZ and I6R05G01.DSP
When the radio is turned on . . I get the error message and the radio continually beeps.
Anyone have any idea on how I can fix this problem ?
Thanks in advance .. any help would be appreciated.
harryshute
I have gone into Radio Maint .. and have retrieved the following from the radio in question. I don't understand all of it .. but thought it may help in resolving the problem.
  • LPE200.doc
I have checked my service manual for the LPE and well it is just a bit over my head. So hopefully someone will come up and indicate what the problem is.
i think the problem is hardware not connected i seen a lpe-200
do this on boot i have hit the radio in my hand an rebooted
radio and radio works fine leading me to think its a hardware
unpluged a board not connected provoice board or an bad board
in the lpe-200 the lpe-200 still does this ever once in a while
and i think i need to take it apart and check the boards
also a nother lpe-200 every now and then will be monitoring
a system and the radio flashes hardware error and reboots
then works fine
