mitbr
Ok...Its been awhile since I frequented these forums was spending allot of time here many years ago so thought I would let people know how I have my live stream setup.
I have been streaming my scanner since the 90s and have tried many programs and also stream alpha tags with my stream. Here is my setup.
I use Steamcast as the server because it is free, and lists you in all the yp directories , Icecast,Shoutcast,Steamcast, and is fully configurable you can get it here and it is available for Windows and Linux
http://www.steamcast.com/downloads/steamcast/steamcast-0-9-75-beta-win32.exe
I use the standalone Oddcast encoder v3 because it is free and allows all formats , mp3.aac. aacplus ect you can get it here
http://www.oddsock.org/tools/oddcastv3/
You will also need the Lame encoder for this to work you can get it here
http://www.free-codecs.com/download/Lame_Encoder.htm
once you download the Lame enc you move the Lame.dll into the Oddcast folder.
I use the NEW VERSION of Scanner Metadata Generator because its free and avoids having to use the Simplecast enc which is not free and the serproxy prog to use alpha tags in your stream. Thanks Webdinger !!!!! This program allows you to use alphatags on your stream for the following scanners...Only Uniden scanners...BC8t,245,246,250,296,396,780,785,796,895, and 898 Oh yes it does work with the BCt 15 and probably the 996 Whew thats allot of scanners. This program is also fully configurable ie: adjusting delay time,adding realtime text messages, offering scanning message when no signal being received, multiple baud rates,multiple ports,and many other features. You can get it here
http://www.webdingers.com/scanner.html
If you dont have a static ip address try no ip . com get it here
http://www.no-ip.com/
Want info on how to forward your ports on your router get it here
http://www.portforward.com/
If you dont have enough bandwidth and you want to stream to a host provider check out the reviews of the various providers get it here
http://www.radiotoolbox.com/hosts/
Thats about it need further help let me know. I hope this helped some of you out there that want to stream.
Tim
KG4JJS
Webmaster of the Tampa Bay Radio Page
http://www.knology.net/~res0plht/Mi01000.htm
Tim
KG4JJS
