SDR# TETRA Demodulator Trunk Tracking Demonstration
hamradionl
Maby a free donation for his huge efforts to the world listening community?
Like the guys from DsD fastlane doing?
mrscanner2008
Canada
Hi thewraith2008
thanks for you great work.
I try to run TTT on 2 Windows 10 computer and I have this Error
I search the web and tried different solution but no succes. But with my other computer on Windows 7 its work great.
Anybody have a solution ?
thanks
hamradionl
Go in to the SDRSharp.exe.Config
<add key="minOutputSampleRate" value="32000" />
change to
<add key="minOutputSampleRate" value="48000" />
thewraith2008
Hi thewraith2008
thanks
You must start SDR# in WFM mode and with a bandwidth of 25000-30000Hz then start plug-in. (checkbox "Demodulator")
Ubbe
Stockholm, Sweden
From where do the audio recorder take its audio? My recordings sometimes are distorted from bottoming out and isn't heard live from the loudspeaker. I use VB cable and I've tried lowering the SDR# volume (from 50 to 40 in TTT) and go to 50% at both input and output of VB cable. I can't hear any changes in the recordings.
/Ubbe
hamradionl
no succes, still the same error message.
No you did not set it correct in YELLOW is the
<add key="sampleRate" value="48000 sample/sec" />
Can you read below, please.
Go inside SDR# folder got to file SDRSharp.exe.Config
Find the line <add key="minOutputSampleRate" value="32000" />
and change is
==>>>>> <add key="minOutputSampleRate" value="48000" />
mrscanner2008
Canada
and change is
Already done this to :
thewraith2008
Still looks like you have not started (playing) SDR#.
Does your dongle work with SDR#. (without starting the demodulator)
tetra_x86.zip - temporary mirror for the new original tetradec plugin
thewraith, please look at it
Why. What I've done here is a fork of what TSSDR is doing.
It now has a different feature set. And he's new version will NOT work with the current version of TTT.
I may not continue if he has restarted he's efforts.
If I could contact TSSDR, I would ask if he minds with this forks existence and continuation.
