SDR# TETRA Demodulator Trunk Tracking Demonstration
thewraith2008
Download still works OK.
There are three ways to do it. Just don't use 'Download as ZIP' as that is not right.
  1. Highlight file and select the down arrow icon at bottom right of screen.
  2. Highlight file and select the "..." to the right and select Download > Standard download.
  3. Highlight file and right click it and select Download > Standard download.
Latest version (v1.8.6.0) can be found here: MEGA - Download
Release post here
oz1jua
Copenhagen
Yes the best version ever. Thanks for the great work TheWraith2008. The only thing I have seen is that somtime it do not update text for the LA.
But I realy like that you have this integrated in the new version. I now have to find the missing towers in my city.
Thanks Again.
KrisMar
Hi there, very good program works very well. As far as audio recording options are concerned, when VAC is set to "2 channels 16 bit 48000 Hz" the message "ERROR-(samples/sec)" pops up. I had to create a VAC channel and set "1 channel 16 bit 22050 Hz". My question is if it is possible to edit the names "MNC" and "LA"? If someone had such data he could enter them and TTT program would show them in the window like "MCC". This would be a great solution because during propagation you can receive many stations from far away and you would know from where the signal is being received, what user.
vselic
Yeah I know, "this program is tottaly useless" and "it's useless piece of software" because everybody knows how easy it is to circumvent encryption and the laws around doing so. It's not like encryption is actually designed to stop people listening at all. All is required is a simple XOR and your right to go.
Comments like this really inspire me. :rolleyes:
Hello,
i didn't want to offence you or to discredit developers, i just wanted to say, it's useless in many countries, because all of the tetra is encrypted... so it would work only, if you could bypass encryptions, which is probably illegal in most of those countries...
thewraith2008
...The only thing I have seen is that somtime it do not update text for the LA.
Where does this occur? Plug-in or TTT.
Can you give more details.
...As far as audio recording options are concerned, when VAC is set to "2 channels 16 bit 48000 Hz" the message "ERROR-(samples/sec)" pops up. I had to create a VAC channel and set "1 channel 16 bit 22050 Hz".
Not sure why this occurs, I looked at my Virtual Audio Cable settings (which worked OK) and it uses the ranges 1-2 channels, 8-16 bit and 22050-48000 Hz.
Both TTT and plug-in can do this. Please read through the documentation.
Release post here
wiskeymike
Morocco
Hi everyone ! I would first like to thank thewraith2008 for his continuous efforts in updating his wonderful program. Please I have a question about using sds location . In my city the tetra network use sepura system that use the ETSI location standard reporting. Will the TTT software be able to recognize this protocol and show the devices locations on the LRRP program?
thewraith2008
TTT + plug-in will show short or long location responses so long as the network returns them to the BS downlink.
Most of the time this will not occur, you will only get the BS to MS request or BS to MS acknowledgement of the MS response (to the request).
Release post here
causeway74
Hi, I'm running latest version of the plugin, which works fine with 1.0.0.1822 SDR#, however, the crashes when recording are still not handled as expected. There was a note in the manual about this being trapped with error handling but unfortunately I still experience the same. Everything works fine without recording enabled.
I have already tried using DirectSound over MME but no luck. Audio is piped out to VBCable. In some instances I do get a few recordings generated but ultimately there is a crash.
thewraith2008
Without out any crash logs (from TTT or Windows), this will be difficult to locate cause of crash.
Does Windows not generate any events for the crash in "Event Viewer"?
We discussed back in this post about your recording issue (which turn out to be the filename length).
I asked a few questions that may apply here to tracking down the issue.
Does this crash TTT? You say YES
How often does this occur? You say most of the time, but sometimes works.
Is there a error number with the message? You say no, just crash of TTT
When does this error occur. At program start, after period of time, on closing, after changing a option?
What is TTT mode (Single/Dual) and it's selected record options and are any logging option on.
In addition to the questions above:
Does the crash occur at the very start of call, through the call or at very end of call?
Does turning the recording OFF stop the crashing?
Release post here
causeway74
1002 Application Hang error logged in event viewer followed by a Windows Error Reporting 1001
Should I expect to see a TTT crash log? Nothing in the root folder.
This was where no files were created at all - I'm now operating out of root of drive so that issue isn't applicable here.
I'm running in single mode, plugin works as expected when recording is disabled so nothing suspect with the plugin or settings.
Crash appears to happen at the start of a call, I haven't noticed a set pattern though as there isn't much activity in my region. I have turned off recording and everything has been working fine for the past few hours.
The strange thing is that yesterday I noticed a couple of successful recordings in the directory. Could it be that a specific type of call is problematic, but others are fine? If there is anything in any of the .txt files to look for I'll certainly have a look.
Release post here
thewraith2008
OK thanks for the feedback.
Not if TTT is crashing/hanging.
Honestly I don't know.
Only two things come to mind when you say that it only occurs at call start:
  1. File path is too long.
  2. Issue setting up the recording.
#1. seems unlikely as you say your running TTT from the HDDs root folder (e.g. C:\TTT).
I have just added a test for this (path length) and it will show message in status window when condition is seen and no recording will attempted.
#2. The record method (MCI) is a bit dated now and problems maybe occurring in Windows 10 (if you are you are using it).
If a call to the recording system is hanging for some reason, then any error trapping is not going to fire.
Only returned errors from calls are handled or other basic runtime errors.
I can't think of anything at the oment to test/look for to help with this.
Release post here
causeway74
Release post here
Thanks, will have more of a dig. Might try ProcMon to see if any attempts are made to write to the directory, and whether or not that fails.
thewraith2008
I've been doing some testing and when there is a file path issue, TTT handles it.
If the is a problem with the recording tmp file (i.e. file locked), TTT handles it.
It is possible that Windows 10 is blocking TTT's ability to use a sound device (virtual cable) to record from?
I vaguely remember this was something affecting DSD+ at one stage when Windows updated.
I don't know it this also occurs on program updates as well.
I'm not sure if you need to allow TTT to access a (record) sound device or not.
I don't use Windows 10 to be able to look.
Release post here
senavick2
Auckland New Zealand
Hi team, I for one am so very grateful for this update.. I loaded it with a fresh version of AIRSPY 1.0.0.1.1828. Running Windows 10 with
recent updates.. Once configured the Java requests enabled it worked perfectly straight of the key stroke.. Very lucky to have a system
not carrying encryption that I have seen...Perfect audio..
In closing my very great respect and thanks to the author and those assisting with testing etc.
Kind Regards,
Shane Vickers,
New Zealand
LA6FRA
Stavanger. Norway
Hi.
I have one SDR dongle running SDR SHarp 1.716 and TTT plug in. I can only listen one spesific TG or all the TGs in the system.
I wonder if it could be possible to run multiple TTT plug ins with only one SDR dongle and one sdr sharp.
I run sucessfully multiples VFO's (with aux VFO plug in) and multiple DSD`+ and managed to listen specific talkgroups. (The DMR system I listen has 32 TGs and I listen only 3 TGs with separated audio output using multiple VD cables.
thewraith2008
Have a look at this thread (TetraNetMonitor)
This creates multiple VFOs to monitor the carriers.
This works with calls in a first in first played basis. (i.e. does not play calls from different VFO at same time)
Release post here
merlin
DN32su
TETRA is a tough cookie to break. You have come far, stay with the project.
merlin
DN32su
I need the line that is circled. As many as you can, and from different people so I can validate my method.
The carrier is "Current:" 2604 with the frequency of 865.1125 MHz.
What I gather is you need two different sets to calculate a Fb from then see if the formula works for others.
