The Cobra 148GTL was the best CB ever made, but that was 43 years ago! Now what?
KK4JUG
GA
SSB triples your channel usage.
But it doesn't triple the number people out there waiting for your signal. I know there are a lot of SSB radios out there but I believe they're still in the minority. That said, I'd still get the SSB.
Blackswan73
Central Indiana
Hands down , the best CB of the past was a friend's complete CPI 2000 base station, back in the 80's, nothing else even came close.
The Cobra 2000, was just a 148 and a power supply in a fancy base cabinet. Also same radio as the President Washington, and the Robyn 520D
dave524
Niagara, Ontario , Canada
I don't know about how well they work, seeing as I have never heard one on the air, but they sure look cool to me.
He had the complete station, the CPI 2000 base, the matching external frequency counter, the matching Range Plus receive preamp and Talk Power speech processor, it was built with better components than some ham gear of that era. I drooled over it and then I was running an old silver President Jackson export radio which was also a decent old radio in the 80's.
prc117f
Plugged in my Uniden Pro 520xl and nothing but static on 40 channels. This using a spring mount d 102 whip. So looking for CBs to buy might be a moot point unless its for using it for communicating amongst family etc.. now you have all channels to yourself.
SnowWalker
Rossland, BC
Were you getting nothing but static even though you squelch was maxed out?
prc117f
no with squelch off :)
Actually I am getting lots of local stuff in the afternoon. and nights, I was surprised.
Unfortunately my "Base" antenna is a Sirio performer 5000 magnet mount hitched on the aluminum roof.
but got plenty of contacts, chats etc.. looks like people still are pretty active locally. was told that truckers using ch 10 for loads, and 3 other channels for other use.
Borrowed an Icom IC-7200 export CB radio and got plenty of contacts and good reports using the stock mike. The quality of this radio is huge compared to the other stuff out there.
599
Montreal,Quebec,Canada
This is an amateur radio transceiver, not an "export CB radio" !!!
this is why cb's don't even compare even though the IC-7200 is an entry level transceiver.
RFI-EMI-GUY
And shortly there after voided the acceptance certificates of all the 23 channel radios making them illegal to use.
Actually they remained legal to use. It was the importation and sale of 23 Channel radios that was banned. You can use a 23 channel radio to this day.
jhooten
Paige, Republic of Texas
I beg to differ. I have ran the numbers of all the 23 channel radios I have in the shed. None of them show as valid in the FCC database. Without a valid number in the database and the requirement to only use approved equipment how are they legal to use?
RFI-EMI-GUY
Read page 8 of this old magazine, top right column.
http://www.americanradiohistory.com...-Electronics-Communications-Handbook-1977.pdf
For the most part FCC certification rules are intended to control importation and marketing. Grandfathering the further use of previously certified equipment is common.
"§ 95.335 Operation of non-certified
transmitters prohibited.
Except as provided in paragraph (a) of
this section, no person shall operate a
transmitter in any Personal Radio
Service unless it is a certified
transmitter; that is, a transmitter of a
type which has obtained a grant of
equipment certification for that service,
pursuant to part 2, subpart J of this
chapter. Use of a transmitter that is not
FCC-certified voids the user’s authority
to operate that station. See sections
302(a), (b), and (e) of the
Communications Act (47 U.S.C. 302(a),
(b), and (e)).(snip)"
Nothing in the rule stipulates when the radio received certification. If it has a certification label attached, you are fine. If you have a car built in 1947 and it still runs and the safety equipment required in 1947 still functions, it is street legal.
"§ 2.927 Limitations on grants.
(a) A grant of certification is valid only when the device is labeled in accordance with § 2.925 and remains effective until set aside, revoked or withdrawn, rescinded, surrendered, or a termination date is otherwise established by the Commission.
(b) A grant of certification recognizes the determination that the equipment has been shown to be capable of compliance with the applicable technical standards if no unauthorized change is made in the equipment and if the equipment is properly maintained and operated. The issuance of a grant of equipment certification shall not be construed as a finding with respect to matters not encompassed by the Commission's rules, especially with respect to compliance with 18 U.S.C. 2512.
(c) No person shall, in any advertising matter, brochure, etc., use or make reference to an equipment authorization in a deceptive or misleading manner or convey the impression that such certification reflects more than a Commission-authorized determination that the device or product has been shown to be capable of compliance with the applicable technical standards of the Commission's rules.
[ 80 FR 33441, June 12, 2015, as amended at 82 FR 50826, Nov. 2, 2017]"
By the way, the CB license I held back in the late 60's 70's is nowhere to be found on FCC database. Some stuff just ceases to be of record.
dorslv
Denver
Cobra 2000 GTL
well, i'm glad I did not sell my Cobra 2000 GTL and Astatic D-104 Silver Eagle then.
EMTJD
No, not really. That was marketing hype that a lot of folks bought into. There were only 23 channels, and later 40. I'm sure most of you know, but the lower or upper sideband is only that part of the single channel. It is NOT two additional channels.
You still have a 4 watt transmitter, but you're taking the power that is spread across the carrier and both sidebands and using it on just the one sideband. Therefore, 12 watts, effective power.
