- Joined
- Nov 19, 2008
- Messages
- 1,623
I was wondering if somebody could tell me exactly what software I will need to program this version of radio and exactly what software CPS version to buy from Motorola
I thought CPS 2.0 removed Bluetooth programming capability.For a Motorola XPR7550e radio that has recently shipped, CPS 2.110.120.0 will be needed for programming. This is ran on several Dell and Panasonic Toughbooks, all running a version of Windows 10, but CPS 2.0 will work on Windows 7 as well. This software is slow, even with a cable so I do not even bother with Bluetooth tethering a PC and radio for programming. I use USB programming cables, PMKN4013C and a newer USB cable PMKN4012B Rev B dated 11/22 for programing XPR7550e radios.
Yes, for clarification, 2.0 did remove Bluetooth, that was more a response if 16.0 was being used (which would be more for XPR7550 radios not the "e" versions). "e" versions need CPS 2.0, or at least the ones I have received for the past 3 years, all have been some version of CPS 2.0.I thought CPS 2.0 removed Bluetooth programming capability.
I’ve actually found that “Bluetooth” reading and writing is faster than USB on my r2.09 CPS 16 setup. Or…is Wifi reading/writing a third, separate option from Bluetooth? This has always confused me. I need to click the Bluetooth button in CPS, but then get my radio on Wifi and define an IP address, then read/write. That has always been MUCH faster than USB in my experience. But I don’t think it’s actually communicating over Bluetooth.
Radio Management is also free, and if you find yourself frequently programming your XPR7550e, using RM to program the radio over WiFi is really slick. There are a few ways to get there, but I used CPS and a cable to initially add the WiFi config to my 7550e. From that point on, the radio automatically connects to my WiFi, obtains an IP address over DHCP, and can be programmed using RM.
I did add a DHCP reservation into my firewall so that the radio always gets the same IP address, but I don't think that is required.
If you wish, you can program a button on the radio to turn WiFi on and off.
Bluetooth mode should more properly be called TCP/IP mode
Generally EID's have to be purchased through a Motorola dealer. But the Wideband EID is free through Motorola Myview website, you have to watch a 15 minute online tutorial then you can add it and download it to your computer and program widebandAny one have a deal on EID's For CPS 2.0? I need 1-5 of them for me and my buddies with radios that wont do cps 16.
If so P/M me please. NEED 25KC.
TKS.
