I think that reviewing low-end receivers with the recommendation to just buy something else is what leads to reader frustration.
Fix: Pull knob. Remove felt covering over encoder shaft nut. Tighten nut just snugly enough - do not strip it or place enough pressure to break plastic. Replace felt and knob. Small wrench will do it without (even small fingers might do) without having to disassemble the whole thing. Loose knobs? A small strip of white silicone plumbing tape around the pot threads works nicely. Had to do this on my 350.
My first 750 which got sold got this fix applied. My second and third 750's do not exhibit this problem, but I know how to fix it should it come loose. Recommend not using the dimple which will exacerbate the problem. Update: just snugged up one of my later ones. Took about 15 seconds total.
Yet everything from your username, radios mentioned in the message, and tagline are all made in China! There just aren't any other players in this market segment anymore. ALL Chinese receivers could use more Q/A and better componentry. Until a competitor comes along, they own the market and can do as they please.
The best favor you can do is use the radio that best fits the job. I have a PL660 myself, and consider it a nice radio for an ultra-portable, but I could easily SHRED it technically as compared to the feature set and usability of the 750. One is a tabletop, and the 660 is an ultra portable - two different radios that really shouldn't be compared together.
If I wanted to trash the 660, (which I won't), I'd have to decide if I wanted to play the specs game, or the usability game. it's all a waste of time really unless one steps back from the nitpicking, and take an overall view of the situation to be fair to the readers.
I started in '76 with lawnmower money with this:
RigPix Database - Heathkit - SW-717
If I was just starting out today, I'd go bananas over a 750!
I think reviewers would do themselves a favor by just sticking to the radio under review, rather than comparing it to everything else.
For the money, the 750 - even with it's own imperfections, is the best bang-for-the-buck tabletop receiver out there - to have FUN with. I currently use it for chasing down longwave NDB's, BCB dx'ing, amateur/utility ssb-cw, and all the way up to airband monitoring. I use most of the features.
Note - I also have done the am-output level mod, which performs better for me than using drastic amounts of attenuation / rf gain. The mod consists of a 2.7K resistor in series with a non-critical 22uf electrolytic cap from pin #18 of the receiver chip to a convenient can shield. This is mostly for ssb/cw usage, although one can get by with the stock controls. Long thread on the Yahoo groups about it - not my mod btw.. (the 660 could use some of the same, just like its predecessor, the 600)
This mod is mainly due to the fact that I use outdoor antennas affixed to each of the 3 dedicated antenna jacks.
