for grins i'd try an sds100, or find someone that has one. there is a guy in austin that is having the same issue. sometimes more antenna isn't the best route, with that yagi, i'd turn on the attenuator and try pointing it at some different sites. most of the intellirepeater sites in austin went to full simulcast sites, so now there are even more antennas all transmitting on the same control channel. when you look at the signal strength, it's all over the place. so even with a good antenna and good coax and in theory what looks to be good enough receive signal you could be seeing what they call simulcast distortion and that 436 just isn't going to cut it, assuming you're trying to monitor a simulcast system. just trying to think outside the box
