Tk-2312
cadkins902
ok ive recentally got a asst.chief spot on teh fd and we purchased many of these radios. Im just about new to teh programming side of these tho.. I need help on putting a DTMF identifer in it and also setting up a tone part for when pagers go off the radio will as well..If anyone can help plz do so.
Av8tor56
Roswell, NM
I don't any experience with the 2312 but for most newer Kenwoods the steps are basically the same. For paging you want to set the optional signalling to 2-tone on the channel used for paging. there should be 2-tone 1, 2-tone 2 etc. Set that to the paging format you use. Then set the tones that you use in the signalling tab of the dropdown menu. If you set the other channels to DTMF in optional signalling, set the identifier in the optional features, and set it for either BOT or EOT it should work. Also you will have to set the DTMF identifier in the DTMF dropdown. You may also have to change the digit speeds as some newer Kenwoods won't decode DTMF as fast as the older ones will.
Wish I could be of more help but I don't even have the software for the radio so I can't dummy up a codeplug to see how it sets up.
egrs40
You also want to change the "audio control" at the top of the screen to QT/DQT +/or Optional Signaling. QT/DQT + Optional Signaling if you don't want any audio to come through until an alert is received; or Optional Signaling if you do want audio to come through before the alert is received. I don't use DTMF Signaling so I cant really be any help there.
