TK 760H/762H
wdugan
Ewing, KY
I am having some problems with both these radios they will receive but will not transmit I don't see anything that looks wrong was wondering if it was something turned off in program not really sure just need some help if possible I have 3 radios 2of the TK 70H and 1 of the TK 762 and find it strange all do the same thing any help will be appreciated Thanks
cabletech
Puget Sound
When you build the programing, did you enter a transmit frequency as well as the tones (if needed)?
Did you accidently set the channels up for recieve only?
WX9EMS
Lake Geneva, WI
Do the radios show that they are transmitting (red tx light)? Have you checked output power? Are there any error tones?
These radios are pretty straight forward to program. I would recheck your programming and if that comes up empty, check the other two items. Try a different microphone if you have one. If you still can't get anything out of them, then you most likely have a hardware problem.
kayn1n32008
ØÆSØ
Sector 001
Out of band TX freq?
Sent via Tapatalk
These radios are pretty forgiving out of band. I use one and it seems to do well down to 144.000 even though it is a 148-174 band split. My transmit frequencies are from low 144 to 173MHz. I have not had any issues.
The radio may just need to be out on a bench for a proper alignment though
Sent from my iPad using Tapatalk
WX9EMS
Lake Geneva, WI
The tones you hear are error tones. They are telling you that the radio either has no transmit frequency programmed or the tx vco is out of lock. What frequencies are you trying to program? Like mentioned above, they are designed for use in the 148-174 MHz range. They will usually go outside of this range maybe 5-8 MHz, but if you are asking it to go further than that the VCO's will unlock and a full alignment may or may not make it work where you want it to.
wdugan
Ewing, KY
This may help a little I have noticed that on the display screen the upward arrow has a line slashed thru it and is displayed all the time when I key the mic it displays another upward arrow with out the line but wont transmit some channels have it others do not with the ones that don't it works fine is there something I'm missing I don't see anything different in the programming and I'm within the freq range 148-174
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9900; en-US) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.1.0.1047 Mobile Safari/534.11+)
It may be a busy channel lock out setting. Where a non matching PL is being detected and causing the radio to not transsmit.
MTS2000des
5B2_BEE00 Czar
what he is describing is indeed busy channel l/o. If the channels on which no signal is present (the indicator with the arrow point IN means there is a signal present on that channel) allows transmit and the ones with the indicator on prohibit, press the MONITOR button to see if the channel is in use by someone else.
Squelch threshold may need adjustment, or disable BCLO on each channel (but me mindful of others if the frequency is in use before keying up, which is a requirement under FCC rules in most radio services).
