TK7180 DTMF mic backlight
Batt54
Veneta, OR.
I picked up a new in box 7180HK with the remote head install kit recently. Part of my setup was to use the optional DTMF mic for the extra functions option. I noticed straight away that while all the functions worked properly and the radio performs very well. The backlight for the mic does not work. I plugged it into other 7180HK's as well as a 7360 and 7160 and it worked. Anyone had an issue like this and could it be related to the remote head kit as this is the only radio in the fleet installed this way.
Check Pin 1 on the microphone RJ-45 jack on the control head. That's the source of the mic backlight.
Try removing KRK-10 and reconnecting the control head directly to the radio and see if that fixes it.
There was an issue with some early KRK-10's that one of the internal connectors was installed backwards, but I think that resulted in the control head not functioning at all.
If the control head backlight is working with the remote head KRK-10 installed, I'm going to lean towards the issue being in the control head. Mic backlight isn't a function that's passed all the way through from the radio deck. It's handled inside the control head.
