Chaos703
Unless otherwise indicated, does a repeater's input freq use the same tone as its output freq? Or do inputs not use tones?
Chaos703 said:Very helpful. Thank you. But I should have been a bit more specific with my question.
When using the database for this site for programing, is it safe to assume that I should always enter the tone on both the "frequency" and "input"?
2112 said:You generally would program only the frequency listed under in the "Frequency" column, as this represents the output of the repeater, and thus, provides the strongest signal. If you must listen to the repeater input for some reason, it is usually safe to assume that you would program the same tone.
KD5WLX said:In general, with amateur repeaters, the use of a tone is to prevent interference from distant repeaters keying them up when the band opens. Thus the only requirement is to put the tone on the transmit freq - no tone is required AT ALL to receive on their output, and the only reason to ever monitor the input freq would be if you were fox-hunting an interference source. Hams sometimes put a decode on the output on their receivers, but that is only to avoid occasionally hearing the "static" when a band opening starts bringing weak signals in to the area..................<snipped to save bandwidth>
KD5WLX said:2B,
I know what you mean. It drives me nuts with the church radios (460MHz business band - leased on shared freqs). There are other "customers" of the radio supplier that use the same freqs but different PLs. Since they're mostly weekday users, and we're mostly night and weekend, it's rare that a conflict occurs. But there is one agency (a towing company) that runs 24x7 on the same freq as our Ushers. And no one knows that if you don't hit the "mon" button (and thus hear them) that if the green light is blinking and you key up, no one hears you, OR the other guy, and since he doesn't know what it means, either, you'll both double AGAIN and still no one hears you, so you'll both......
They just don't understand that PL decode means (1) they aren't disturbed by transmissions from the other user but also (2) FM doesn't work if two users hit the repeater at once and (3) you MUST listen before you key up (or at least look for the "busy" light).
And of course, no one at the church or the tow company would have ANY clue what freqs they were using, let alone PLs - you'd have to get those from someone who "snooped" them or from the company that leases the radios to us.
