TP8100 Firmware issue
Disp46
I’m trying to program a recently acquired TP8120 UHF radio and I keep getting a database mismatch error. I think I may have some glitch in this radio because my firmware version shows FW Vers 22.47.20 and Main DB 90.02. This seems very odd since my other TP8100’s show FW Vers 1.08.00 and Main DB 1.03.00. Do I have corrupt firmware? This radio came from Canada and I’m in the US but I don’t think that should matter since there doesn’t seem to be different versions across the two countries. If it’s firmware, can someone get me a correct clean version for the TP8120? Thanks!!!
E5911
the lower desert
I just got my cable and software, on my uhf 400-470 same issue
How do you upgrade or do I need older software than 2.16?
anthonyf96
Can you help me out? I'm trying to figure this out too
carrionj50
Greensboro
Hello
I used to use these radios back in my country; I am a former volunteer firefighter.
I just bought 3 of these radios. But when I try to connect to the programming software and click on read, an error appears (" The radio database version is not supported. Please upgrade"). I tried to upgrade it, but since I cannot access the radio, I couldn't save the calibration settings.
So, I tried to do it without saving those settings. Now, I have one radio needing calibration haha. But again is the same, when I tried to calibrate it with the program, sometimes it says "No prompt returned. [geltem]" :( HELP!!
speedn360
Charleston, TN
Is there a resolution to this? I am in the same boat and very angry and frustrated. I cannot believe how poorly documented these radios are.
headsense
Australia
It is highly probable as you guys are discovering you have a mismatch between firmware and CPS and this is because typically firmware at V22.X.X or something like this is customer specific custom firmware.
This is very common practice and custom firmware requires custom CPS which you will never find. Custom firmware is often implemented to allow integration of console features thing like emergency alarms and signalling as an example.
The simple fix is a flash back to generic factory firmware and use the matching or most current CPS usually. If a customer and application can handle generic CPS and Firmware that's what will always be issued first.
Generic firmware is available in 2x formats being MPT type and Conventional type.
For version TP8100 series portable radios
Conventional V1.12.00 and MPT V2.13.00
The matching CPS is V2.16.00 for both types.
The matching USB driver is V2.9.0.5 for the factory programming cable
The matching TP8100 Calibration Application is V2.15.00.0000
The Firmware upgrade tool V1.27.1.23
This information is valid from <2020 , however this product is getting quite old and may be at end of life so there is still later CPS and Calibration support but not necessarily firmware updates.
Programming cables are a 2x part kit consisting of a Mobile radio cable TAIT USB TO RJ11 PROGRAMMING CABLE PN T03-00118-0601 with a pig tail adaptor DB9 SERIAL PROGRAMMING CABLE PN T03-00118-5101
They can be purchased as two part numbers and together retail for about USD $ 290.00 available Ex USA distributors.
A generic Chinese made aftermarket portable direct to USB single cable are easily sourced through New Zealand and Australia and available for AUD $ 80.00 plus shipping so a very simple reliable for USA cheap aftermarket option.
Reliable and pretty tough hardware radios with a lot of heritage in mining and emergency services (Prior to P25 roll out) so worth persisting to recycle them. Also a lot of support an knowledge in the communities closer to the manufacturers point of origin.
speedn360
Charleston, TN
Thank you for the detailed response and follow up. I do really like the radios, but the numerous issues I had just getting the CPS software to run has turned me off to buying any more--at least of this particular model. While the radios themselves are really nice, easy to use, and have a really sturdy feel, they're really just not a good fit for me in this case.
carrionj50 above was kind enough to converse with me via email and assisted me with the process you described--flashing firmware to the stock version, and this did allow me to then read/write to the radio. So big thanks to him for that assistance and time.
Hopefully this forum post will help someone else in the future.
speedn360
Charleston, TN
Also, for the permanent record, I could NOT get the CPS software to run on any PC other than my 32-bit Dell Latitude running Windows XP. I also had to play around with installing different old Visual C++ (vcredistx86/64) versions. Windows 10 absolutely did not work, compatibility mode or not. I did not attempt in Windows 7.
