transferring frequencies to scanner from RR> Can someone please show me step by step how to transfer my saved area frequencies to my scanner please? I just bought the premium subscription to be allowed to do this.
IT would help to know which Make/Model Scanner and what Software you are planning on using.transferring frequencies to scanner from RR> Can someone please show me step by step how to transfer my saved area frequencies to my scanner please? I just bought the premium subscription to be allowed to do this.
Thanks, only saw Whistler Forum
Download ezscan for your model scanner from Whistlergroup.com. Update the library.
Once you do that you will have the entire RR datat base in ezscan. Use the library import tab in ezscan to import what you want to ezscan then copy that configuration to your scanner/sd card.
thank you for for your support, my scan list i created still is not showing up on my scanner, the scanner scan list goes from 1 through 150 even though my scan list only included 1 thru 250, Seems it waste a lot of time scanning through the other 125 channnels and im only picking up my local sherriffs dept. which is one of the frequencys i did list.No matter how many time i go back into ezscan and try again it comes up the same on the scanner. did i need to to totally reformat my sd card first or something.?
System Name: | St. Louis Area Trunked Emergency Radio (SLATER) |
County: | 6 Counties |
System Type: | Project 25 Phase I |
System Voice: | APCO-25 Common Air Interface Exclusive |
System ID: | Sysid: 4F2 WACN: BEE00 |
Last Updated: | October 20, 2023, 8:47 am CDT [Added Talkgroup to: Franklin County (55428 Pacific Police: Dispatch)] THIS IS ONE OF THE POLICE DEPTS. I REALLY WANT TO HEAR AND HAVE TRIED TO ADDD THEIR FREQUENCY BYT STILL DONT HEAR ANYTHING DESPITE THE FACT THEIR LITERALLY ONLY 2 MILES DOWN THE ROAD FROM MY LOCATION |
Operator error, In ezscan, Under scanlist tab, make sure have enabled the scanlist you want to listen to and disable the ones you do not.thank you for for your support, my scan list i created still is not showing up on my scanner, the scanner scan list goes from 1 through 150 even though my scan list only included 1 thru 250, Seems it waste a lot of time scanning through the other 125 channnels and im only picking up my local sherriffs dept. which is one of the frequencys i did list.No matter how many time i go back into ezscan and try again it comes up the same on the scanner. did i need to to totally reformat my sd card first or something.?
System Name: St. Louis Area Trunked Emergency Radio (SLATER) Location: St Louis Metro Area, IL MO County: 6 Counties System Type: Project 25 Phase I System Voice: APCO-25 Common Air Interface Exclusive System ID: Sysid: 4F2 WACN: BEE00 Last Updated: October 20, 2023, 8:47 am CDT [Added Talkgroup to: Franklin County (55428 Pacific Police: Dispatch)] THIS IS ONE OF THE POLICE DEPTS. I REALLY WANT TO HEAR AND HAVE TRIED TO ADDD THEIR FREQUENCY BYT STILL DONT HEAR ANYTHING DESPITE THE FACT THEIR LITERALLY ONLY 2 MILES DOWN THE ROAD FROM MY LOCATION
You don’t need to be a premium subscriber to download and programtransferring frequencies to scanner from RR> Can someone please show me step by step how to transfer my saved area frequencies to my scanner please? I just bought the premium subscription to be allowed to do this.
you only get two downloads without being a member, and what you get for your money when you buy the membership is well worth it.
I like all the talk about Whistler not good for simulcast…heck mine is better than my sds200EZ scan updates the database when you use the update tab. This is unlimited regardless of whether you are a premium member or not. In fact, you don’t even need to be a member of RR period. Take it from a long-time Whistler user. Currently using a WS1095 on a P25 2 simulcast system with no problems.
B.S.
