Trbo CPS 2.0
Radioguy789
Ontario
Hello. Hope this is ok to post here. I am just wondering if it’s ok to update to 2.0 and start using it or if there is still bugs or issues with it and stick with the previous version until the bugs/issues are fixed. Thanks
Radioguy789
Ontario
Ok, so there is still lots of issues or bugs with it still. And my best bet is to wait until they get a fix for it sometime. If they do get one for it. Before I go ahead and install it.
PACNWDude
+1 on avoiding if possible. I have found issues with Hex values and just the general navigation of the software. There does not appear to be an "expert view" at all. Currently on the second iteration of CPS2.0. However, new XPR7550e handhelds require CPS2.0 to program, while earlier firmware version could use CPS2.0 or CPS16, at least build 827. Stick with CPS16 if you do not need it for your radio. I was able to test an older XPR6550, and could use both CPS16, then CPS2.0, and then go back to using CPS16, but the file icon defaults to CPS2.0 after using it once.
Radioguy789
Ontario
I am not eager. I went to fix up a radio yesterday and I couldn’t do it because it was done with 2.0. So was seeing if there was any fixes to it yet, so incase I come across other radios that were done with 2.0, because I know more radios will be done using 2.0 now.
So ok looks like then I will stay with CPS16, unless I decide to get another computer to put 2.0 on or until they get a fix for it, since there is still issues with it and don’t want to get screwed and have something happen and not be able to go back to CPS16.
Thanks for the info.
Radioguy789
Ontario
Ok I understand now. I will take the warnings and avoid for now until I hear that there has been a fix and it is good to use. So will stick with CPS 16.0 and continue using it. Thanks
N1XDS
ÆS Ø
To me Motorola MotoTRBO CPS 2.0 is like Microsoft excel hard to use if your not use to it.
alcahuete
Southern California
If its 2.0 radios that you're programming, you aren't going to have a choice. You can't program a radio that is has been programmed in 2.0 with 16.0
That said, you can run both simultaneously so you can cover both types of radios. As others have mentioned, if the radio hasn't been upgraded yet, don't. Really no benefit, but SO much to lose.
RRR
OFFLINE
USA
Besides the "Drag and drop", is there -any- benefit to updating to 2.0?
