Treetops site
dmchalmers
I think they just changed the name in the database... :unsure:
i've done many 24 hr searches off Gaylord 2 being east of the so called coverage area am nothing so was curious, ty very much i'll keep trying only within range of Atlanta 2, Mio, an Lovells others are on frindges
also been doing a Close Call with no results?
Admin will automattically say its operator error!
If Gaylord 2 has been renamed to Treetops why hasn't the powers to be corrected the the DB an said the change?
Why wasn't posted? eccpect it small population area!
wgbecks
NE Wisconsin
Can someone tell me if this site uses the same control channels as the old Gaylord 2
"Treetops": RFSS ID: 4 SITE ID: 33 was the original primary MPSCS tower covering Gaylord that is located on Marquardt Road.
"Gaylord" : RFSS ID: 4 SITE ID: 47 is a monopole that was constructed more recently along South Otsego Avenue in the vicinity
of the 911 Dispatch Center.
When the new South Otsego Avenue monopole was first constructed, what is now known as Treetops was labeled Gaylord-1 and
the new downtown site was labeled as Gaylord-2. Since then, Gaylord-1 became Treetops and Gaylord-2 became Gaylord if that
makes any sense?
dmchalmers
i'll bet i'm blocked!
makes any sense?
Thank you very much I'll try manually load that since for some reason i can't update Db could be my laptop
hockeyref2
Northern MI
At one point I believe they were called Gaylord and South Gaylord in the database as well.
The MPSCS map calls them Gaylord and Gaylord - Dispatch.
wgbecks
NE Wisconsin
Gaylord, South Gaylord, and Gaylord - Dispatch would be all one and the same monopole on South Otsego Avenue across
from the 911 Dispatch Center.
hockeyref2
Northern MI
The MPSCS map calls the monopole across the street from the post "Gaylord- - Dispatch" and the other one "Gaylord".
